Alot of the same questions get posted all too often about Diesel swaps So here’s a Tech page for those Newbie or wanna be diesel FSJ conversion guys:
Please PM or email me ideas on how to better arrange this or with other threads. Thank you to all who have contributed.
GM diesel swaps:
http://www.ifsja.org/forums/vb/showthread.php?t=14988 6.2/6.5 Diesel owners
http://www.ifsja.org/forums/vb/showthread.php?t=18718 --- The Pig smith J20 with a 6.2
http://www.ifsja.org/forums/vb/showthread.php?t=22615 ---- OhioJ20 " My 6.2 GW"
http://www.ifsja.org/forums/vb/showthread.php?t=57990 - some pictures of installs and discussion about the trials and tribulations of a gm swap
http://www.ifsja.org/forums/vb/showthread.php?t=13952 --- Pig Smith lays out his 6.2 game plan for debate
http://www.ifsja.org/forums/vb/showthread.php?t=78632 --- fsjeeper's project wagoneer 6.2L diesel conversion, some discussion 6bt and 4bt.
http://www.ifsja.org/forums/vb/showthread.php?t=10233 --- Starts out about cummins or ford 6.9 IDI or 7.3 IDI decends into details about 6.2/6.5 conversion
http://www.ifsja.org/forums/vb/showthread.php?t=14988 --- GM diesel motor mounts, adapters etc and links to conversion basics
http://www.ifsja.org/forums/vb/showthread.php?t=96969 --- 6.2 wiring harness info & Diagrams
http://www.ifsja.org/forums/vb/showthread.php?t=20734 --- 6.2 in a M715
http://www.ifsja.org/forums/vb/showthread.php?t=82155 --- Diesel Wagoneer in the works
http://www.4btswaps.com/forum/showthread.php?t=1278 --- Colorado jeep guy 6.2 swap in 1988 Wagoneer
http://www.ifsja.org/forums/vb/showthread.php?t=98972 --- SJdiesel’s update 6.2 performance and 700R4. Good details
4BTA and 4BT swaps:
http://www.ifsja.org/forums/vb/showthread.php?t=66998 ---- tndonors J10 with 4bta, bread truck intercooler and NV4500, pictures of install using cummins accessory mounts.
http://www.ifsja.org/forums/vb/showthread.php?t=81359 ---- Cherokee Chief with 4bta 91-93 dodge intercooler and dodge nv4500 pictures of motor mounts and Dodge accessories & AC
http://www.ifsja.org/forums/vb/showthread.php?t=54096 ----wagonman83’s swap stock 4bt
http://www.ifsja.org/forums/vb/showthread.php?t=81595 ---- Coloradofireman
http://www.ifsja.org/forums/vb/showthread.php?t=101438---- more pictures from Coloradofireman
http://www.ifsja.org/forums/vb/showthread.php?t=69246 ---- MCinfantry’s WC swap, stock 4bt
http://www.ifsja.org/forums/vb/showthread.php?t=103844 ---- 74 J20 zmjeeps 4bta w/ good fitting intercooler
http://www.ifsja.org/forums/vb/showthread.php?t=127496 --------- Willysdrivers 4bta into wagoneer using dodge 727 transmission and 229 t-case. low mount turbo and stock cummins air to water aftercooler 120hp 4bta
http://www.ifsja.org/forums/vb/showthread.php?t=54096 ---- Misc 4bt discussion some pictures and links
6BT Swaps:
http://www.ifsja.org/forums/vb/showthread.php?t=90702 ---- 6BT's are a tight fit, Dodge frame jeep body
http://www.ifsja.org/forums/vb/showthread.php?p=1105743 - FSJ frame strength discussion with 6bt install and reliability links etc.
http://www.ifsja.org/forums/vb/showthread.php?t=120980 ---- TNdonnor is at it again 6BT gladiator with some nice hop ups, twin turbos etc in the planning and build stages.
http://www.ifsja.org/forums/vb/showthread.php?t=59769 ---- Willysdriver using a dodge 6bt 727 transmission, early dodge intercooler and 3.31 axles
GM diesel swaps:
4BTA and 4BT swaps:
6BT Swaps:
