Old 09-01-2008, 06:56 PM
gotmike's Avatar
gotmike gotmike is offline
cummins in a cherokee
just thought i'd show off mine a bit...
my dad had an old '77 jeep cherokee chief that broke down and sat in a field for quite a while... he was about to the point of hauling it to the crusher when i piped up and asked if he'd just give it to me... it was purchased by his car dealership and the title basically dissolved at the same time as the dealership did... so i had a jeep with not title... and no way to get the title... not without alot of work... so i hatched the plan to get the state of wyoming to issue me a new VIN... use enough donor parts and change the vehicle enough that the original vin would no longer pertain. i had just finished paying off my '92 dodge standard cab, and with the recent addition to my family i really needed a back seat... so i took a week, and merged the two vehicles... 3 VIN inspections, an envelope full of paperwork, and 2 weeks later the state issued me a new vin and an estimated value of the vehicle... so in the space of a month i had taken two vehicles and created one monstrosity unlike much any other vehicle within several hundred miles... fortunately i had use of several welders, an overhead crane, and most any other metalworking tool i could need... i fabricated my own body mounts, and pedal brackets along with a slew of other brackets for the clutch reservior, radiator, air filter housing and toyota bucket seats... i found a fuel tank in a buddy's back yard that fit perfectly between the rails behind the axle, and am now installing an onboard air system...
J.E.E.P
Just Everyone Elses Parts!
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Dana 70-HD Rear axle
Build thread: http://www.ifsja.org/forums/vb/showthread.php?t=90702
trailer build thread: http://www.ifsja.org/forums/vb/showthread.php?p=1314880&posted=1#post1314880
Old 09-01-2008, 07:08 PM
TPICherokee's Avatar
Very cool! It has been done a few times before:
http://www.youtube.com/watch?v=i8q4KPP3N2U
and...
Old 09-01-2008, 07:41 PM
gotmike's Avatar
pics
J.E.E.P
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Old 09-01-2008, 07:42 PM
gotmike's Avatar
J.E.E.P
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Old 09-01-2008, 07:44 PM
gotmike's Avatar
J.E.E.P
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Old 09-01-2008, 08:56 PM
Any pictures taken during the swap?
Old 09-01-2008, 09:42 PM
gotmike's Avatar
there were pics taken of almost everything... but my brother changed the batteries in the camera without taking the memory card out... and it fried the card... and all the pics with it...
i started the swap by disassembling both vehicles... i had acess to a crane so it made some things easier... i removed the bed on the truck and then gutted the interiors on both... took the entire dash and steering column out on the jeep and took the column out on the truck as well... i then had to put both columns back in to to keep them moveable... i unbolted the body of the jeep in one complete piece then took the hood off... i left the doors closed and ran one strap completely around the body just behind the doors... i then ran another strap from the middle of the main strap, up through the tranny tunnel and then hooked it to the crane... i was able to pick the entire body off in one piece... that way... and then i just rolled the frame back out the door... at the end of the night i just set the body back on the frame and wheeled the whole thing out... that was the one stipulation my boss made... that i be able to wheel everything out of the way each night... i took some measurements and was able to figure out how much of the frame to cut out...
i cut the frame right in front of the rear axle... on the dodge trucks there is a nice straight section there that was very easy to cut and line back up... i cut the frame at a fairly severe angle to limit the chances of articulation cracking/shearing my welds... i then put a large diamond shaped fish plate on the outside of the frame and welded all four sides around leaving stress reliefs on the very tip... i eventually want to box that section of frame to re-inforce it more... but that will not be easy... my cuts were directly between the two fuel tank cross members so i left them intact to re-inforce the frame itself...
when i made my new body mounts for the jeep body to sit on the dodge frame i set my height with small pieces of metal stacked in to get clearances everywhere i needed them and then took extensive measurements to keep them all the same... i then used an iron worker to notch pieces of 3" channel and bend them over into an L shape and welded the notched parts together...... which i punched a hole in for the body mount itself and bolted them to the "floating" body... when i had all the mounts made and bolted in place i plaz'ed open anyplace where there was an existing rivet in the way and welded them to the frame... i shortened the rear driveline myself too... i just simply cut out the weld and removed the yolk from the shaft and then cut the shaft with our band saw and welded the yolk back in very carefully...
with the dash removed i was able to put the dodge steering column in the jeep body and mount it in place... i was also able to remove the pedal assembly from the dodge and fabricate some brackets to hang them from... i then fitted the clutch master cylinder through the firewall and then the brake booster and master cylinder... i had to build a small bracket for the clutch reservior to bolt to... i used the main dodge wiring harness and re-cut the existing firewall plug hole to accommadate... i took the switch handle out of the jeep light switch and inserted it into the dodge light switch. i bolted the dodge switch to the jeep dash after i put it back in...
to put the radiator back into the jeep i had to cut a little bit out of the top of the front clip and drop it down into the middle space where the factory radiator went... the dodge radiator just uses two rubber feet that drop into punched holes in the dodge body and brackets that cap the same type feet on either side at the top... so i inverted those brackets and welded them to the front crossmember on the dodge frame and them built some tabbed brackets to replace the top brackets on the radiator itself... then all i had to do was bolt the radiator to the body and it was set... the intercooler was a bit more of a challenge... i wanted some fans on the intercooler and had thought of mounting it subaru style up against the hood but there just isn't enough room... so i had to fit it through the grille...
to set the body i had removed the the trans cover and the trans and x-fer case shift levers... i was then able to put some reference marks on the edges of the opening and set the cover back on... then i marked where the levers would come through and cut the openings... at this point i was still sitting on an egg crate for a drivers seat... so i had to fit my toyota seats into place... i had to massage the trans hump a bit on the passenger side to make room for the seat but it was a fairly straightforward install... though the bases are welded in place instead of bolted... more for offroading then for street use...
i cut the bracket for the jeep wiper motor off the firewall and bolted the dodge motor in it's place and the modified the jeep arm slightly to fit on the dodge motor... and bolt up to the jeep assembly... suprisingly there isn't all that much difference in the parts from the dodge to the jeep... since i am usuing the dodge wiper stuff i have intermittent wiper control...
to fit the heater element in behind the turbo downpipe i had to modify the stock housing and put the heater core directly against the firewall... then i used some galvanized sheet metal and made a new cover to direct the air from the factory fan, through the core, and then into the factory heater ducting...
i know there are more details about the swap but it's been a while since i actually did everything...
if i had had more time to spend on things i could have made everything much more finished looking but for having just one week to do all of it and have a running vehicle again i'm pretty happy with the result...
J.E.E.P
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Old 09-01-2008, 09:43 PM
1977cherokeechief's Avatar
1977cherokeechief 1977cherokeechief is offline
is that on the cherokee frame?
nate
the new fixer upper
1977 cherokee chief
360, th400, QT
33" tires
edelbrock 600cfm
82 mustang 5.0 5 speed. ford racing intake, edelbrock, offbrand long tubes, and glass packs.
Originally Posted by jamsni
Just explain that you are trying to do your part to stimulate the economy. Buying it is just the right thing to do.
Old 09-01-2008, 09:49 PM
mattmopar440's Avatar
What the power like good 0-60 time ????
Yes please post more pics during the process
Thanks matt
87' Grand Wagoneer
80' J10 4BT/AX-15/208
74' J10 Go Grabber Green Sold
Inferior Chevy
Old 09-01-2008, 10:18 PM
gotmike's Avatar
no... it's not on the cherokee frame... i modified the dodge frame to fit under the cherokee. gave me more room to work with... and it's got more then enough power... it's running 36 x 14.50's and it'll roast them 1st, 2nd, and 3rd if i let it... with that NV4500 first gear is pretty much too low to use unless i'm towing... and i get better then 20 mpg...
J.E.E.P
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Old 09-02-2008, 02:51 PM
bushwood44's Avatar
bushwood44 bushwood44 is offline
20 mpg and unreal torque that would be nice.
88 Grand Wagoneer
99 Camaro z28
73 Honda st 90
79 F250
Old 09-02-2008, 03:19 PM
El Jefe's Avatar
El Jefe El Jefe is offline
hey. your jeep was in one of the Petersens 4wheel readers rides. Or was it 4wheeler. cant remember. but it was you. bout time you got here.
Nice rig by the way.
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
4" lift, 35 inch retreads
Old 09-02-2008, 05:54 PM
gotmike's Avatar
i just stumbled across it the other day... but now that i'm here it's great to see all these other rigs and know that i'm not the only one with bad taste...
J.E.E.P
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Old 09-02-2008, 06:16 PM
Your not, some of us have it BAAADDDDD!!!!
I hope to one day follow your que and do my own into a '77 J-20. Now if I could just find a motor I could afford.......
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 09-02-2008, 06:32 PM
gotmike's Avatar
i'd keep an eye out at insurance salvage auctions, and junk yards for a wrecked truck... the dodge frame is really very close to the same as the jeep frame... it's just heavier duty... i installed the dodge steering column and braking system onto the firewall of my jeep and kept most of he dodge wiring harness i used the clip that the fuse box attaches to and affixed that to the firewall so that the dodge fusebox isn't just hanging under the dash... and then i welded closed the factory hole where the main harness comes through the firewall and cut a new hole for the dodge setup to mount. This kept the cost down and wasn't all that labor intensive. in the long run, with selling off the leftover parts, i made money doing the swap... so my wife couldn't complain. though i don't count the cost of purchasing the truck... since i had already driven it for 3 or 4 years and it was paid for...
J.E.E.P
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Old 09-16-2008, 12:44 PM
gotmike's Avatar
finally got my fuel tank in... problem is... i don't know what it came out of... it bolted in so easy it's not even funny... and i got my L.E.D's in where my factory tail lights used to be... i'll get pic's up later... now i just need to clean out the interior completely and get it blasted and painted/herculined... that's going to be a dirty weekend though
J.E.E.P
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Old 09-18-2008, 06:04 PM
gotmike's Avatar
here's a link to some more pics... including one of the tail lights
http://s239.photobucket.com/albums/f...ect/?start=all
J.E.E.P
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Old 09-21-2008, 08:14 PM
gotmike's Avatar
got my onboard air up and running too... pics are on the link above...
J.E.E.P
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Old 10-22-2008, 06:52 PM
The PIG Smith's Avatar
King Browless
Question Frame Questions
As I am thinking about a Cummins 6BT Conversation (very long term project) I am concerned about my Jeep Frame and have some questions.
When you say the Dodge Frame is heavier than the Jeep frame, I am assuming that that you are comparing
a Jeep Cherokee/Wagoneer style frame to a Dodge 3/4 ton pickup truck frame.
I am considering a Cummins 6BT in a J truck.
So, would like to think a 3/4 ton Jeep frame is about the same strength as a 3/4 ton Dodge frame.
There has been some discussion on this forum in the past that if a person uses a Jeep Frame for a 6BT swap,
that some reinforcing of the frame is required (boxing?)
But, I will assume the folks that report this modification requirement is speaking about the 1/2 ton rated Cherokee/Wagoneer frame and not the J Truck frame.
I am writing to ask that you elaborate on the why you felt you needed to use the Dodge frame.
What does the Dodge frame provide?
Deeper frame rails?
Thicker material?
Stronger steel?
If you convince me that a Dodge Frame is the way to go, would a frame from a Dodge 2500 gasser be the same as a powered be a CTD?
Bryan Smith
Originally Posted by Jayrodoh
Originally Posted by Lindel
Old 10-23-2008, 04:12 PM
gotmike's Avatar
the frame on the jeep was 4 or 5" channel... the dodge frame is 8" channel it's heavier steel and it has some very stout cross members... it is definately a stronger frame... plus it's got a dana 70 rear end... i would think that the frame on a newer gasser would be strong enough... but i don't know off the top of my head... and i could be wrong but i don't believe there's much difference in the frames between the half ton or 3/4 ton jeep frames just a difference in the springs and axle... are you planning on lifting the truck or keeping it low for towing? if you are going to lift it as well you would be better off getting a newer frame because once you do the swap you're already lifted... and i had to shorten my frame but you may be able to find a single cab short box to pretty much match your current wheelbase... it's really up to you how much money you want to spend and how much work you want to do...
J.E.E.P
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
