Old 03-15-2005, 12:57 PM
ohioj20's Avatar
ohioj20 ohioj20 is offline
My 6.2 chevy Diesel GW
Well, for those who followed our little 6.2 diesel in my J20 thread, my 1990 Gw Conversion is making head way. Got most of the body work done and paint stripped off. Also got the adaptor to a TH700 to a NP 229 today from Advanced Adaptors. Now just need to jack up the body and remove the frame & drive train to swap onto another frame, with the 6.2 and TH 700. All is on hold since the weather sucks in NE Ohio!
Kenny
1982 Jeep J10 body going on 1991 Dodge W250 frame with a Cummins and 5speed
1999 Dodge Durango 5.2 V-8
Old 03-15-2005, 01:15 PM
The PIG Smith's Avatar
The PIG Smith The PIG Smith is online now
King Browless
Wooo Hooo!!
I've been on the lookup for a cheap 6.2L.
I am telling the world here and now, I WILL own a oil burner someday!
For those that have gotten or do not know, check out this link to an event we are having:
Ohioans interested in a 6.2 Diesel into a FSJ
[ March 15, 2005, 07:20 PM: Message edited by: The PIG Smith ]
Bryan Smith
Originally Posted by Jayrodoh
Originally Posted by Lindel
Old 03-15-2005, 01:17 PM
waggin'ear waggin'ear is offline
Brian,
I saw that you were on the 6.2 forum. You must be serious.
adam
Gotta a lot of junk
" I may not be good, but at least I'm slow"
Old 03-15-2005, 01:23 PM
King Browless
I AM!
Very!
I've been researching this topic to death.
Learning all that I can from everywhere and everyone.
I am trying to soak up as much knowledge as I can.
[ March 15, 2005, 07:23 PM: Message edited by: The PIG Smith ]
Bryan Smith
Old 03-15-2005, 03:07 PM
Sycho15 Sycho15 is offline
What's up with the 6.2L anyhow? The 6.5L TD is a superior engine.
1989 J5 "Murphy"
4.0L / AX15 / NP231 / GW D44s
3" lift / 31" MTs
Old 03-15-2005, 04:37 PM
illegalFSJ illegalFSJ is offline
I agree - if I were to go through all the trouble of a diesel swap, I'd definately install a 6.5 TD over that old 6.2 any day.
"Well, what gears do you have? If you have 2.72s in there still, a blown big block with jesus himself working the gas pedal couldnt get the rear tires to slip." -Mavawreck
Old 03-16-2005, 09:17 AM
ohioj20's Avatar
6.2 are a dime a dozen, nothing really wrong with them. Plus, you won't have much room for a turbo, unless you eat some sheet metal! Plus more computer :o:o:o:o:o involved
Kenny
Old 03-17-2005, 12:07 AM
ncjeepers ncjeepers is offline
I've been doing some research, too. I've been restoring and driving military CUCV's for a couple years, I plan to put a 6.2 in a trail Cherokee project, and I am looking at a 6.5TD tow rig.
The 6.5 is not a superior engine by any stretch of the imagination. They have a very bad habit of cracking the main webs in the blocks. Also, you'll have a failure prone electronic injector pump. UNLESS... you get the very early 6.5. The first year or two (93/94 I think) used the old 6.2 "599" block casting and a mechanical injection pump. The troubles started in 94 or 95 when they introduced an "upgraded" block that was prone to cracking. I am gonna stay away from those. They did eventually fix the problem with a new casting, but I'm not sure when.
The pump mounted drivers on the electronic injection pump are prone to failure due to heat and vibration. Also, it is drive-by-wire, which kinda disturbs me. There are kits that are supposed to remedy the failure situation, but I'd much rather go mechanical.
You're not gonna blow anybody's doors off with a 6.2. It'll turn the tires up on my CUCV Blazer pretty good, but I wouldn't consider one for heavy towing. It is, however, cheap and reliable. I get 20mpg in my CUCV Blazer. Parts are everywhere, and much less expensive than other diesels. Reman injectors are $40 ea and a reman pump is $400. Compare that to the prices for the others and you'll see why I like the lowly 6.2.
Tony Casey
BullGearInc.com
Old 03-17-2005, 12:22 AM
crispyboy's Avatar
crispyboy crispyboy is offline
I was looking at a coworkers 1993 6.5T chevy truck that he is selling and I took a few pictures.
Look how big the turbo is on this engine. It would never fit a FSJ without some major modifications to the fender and the you would have to take the heater box out.
Here is another part that you must come up with for a diesel swap.
here is a pricey aftermarket fix - about $660 plus shipping made by Vanco. Looks like the same GM parts as my coworkers 6.5T truck.
Vanco Hydroboost
Steve<br />1986 J-20 360 cid/auto, trac-loc, custom efis tbi, flowkooler, aluminum cross flow radiator, rhino-liner, working AC. <br />1990 GW trac-loc, Engle cam and aluminum cross flow radiator.
<br /><br />\"The best Jeeps came from the past when gay meant you were happy and Aids was an appetite suppressant"
Old 03-17-2005, 12:34 AM
ohioj20's Avatar
you can get away with using your stock Jeep braking system. Just make sure you have both the gear driven and belt driven vacuum pumps. You have enough vacuum with one, but if a fan belt snaps, no brakes! I know it works, cause I have had a 6.2 in my J20 now for 2 years.
Kenny
Old 03-17-2005, 12:48 AM
crispyboy's Avatar
I was reading somewhere yesterday that when a fan belt brakes you still have more braking power with the hydroboost that you do with a vaccuum unit. They also say that the hydroboost system is far superior to the vaccuum booster - but here we go again throwing more money at the jeep.
If I ever do the conversion I figure I will just have to buy a parts vehicle. There is one in the paper for $700 with a bad 6.2 motor.
Old 03-19-2005, 06:05 PM
Soulman67 Soulman67 is offline
The 6.2 diesel is a very good all around engine if you know what to do with them, as well as the 6.5TD. I have had several in the past, my last 6.2 was in a '91 1 ton crewcab. It had been rebuilt balanced and the injection pump turned up 20% and advanced timing, with high flow injectors. It could win drag races and pull. I used it every day pulling 14,000lb. But with all the mods it got 8mpg with overdrive and 3.42's.
88 grand wagoneer, For Sale
96 K3500 6.5 TD crewcab, 80hp ecm, heath wastegate set at 12 lbs of boost, 3\" striaght pipe. 220K broke harmonic balancer off crank.
New DD 95 nissian truck, 4cl 5 speed ain't pretty but gets 21mpg
Old 03-20-2005, 04:43 AM
Carl Rasmussen's Avatar
Carl Rasmussen Carl Rasmussen is offline
I am thinking About putting a compete 6.5 TD with trans and transfer in 78 Cherokee How much room is ther for it in there?
[ March 20, 2005, 10:54 AM: Message edited by: Carl Rasmussen ]
Carl Rasmussen
No more cable bills
Android TV box Full setup and configured $150 https://youtu.be/7bAm9RzIgms
Old 03-26-2005, 12:24 PM
ohioj20's Avatar
Not much! a 6.2 fits snug, need to do a lot of cutting away to fit the turbo, down pipe, and air cleaner.
Kenny
Old 04-13-2005, 08:12 AM
DieselSJ's Avatar
DieselSJ DieselSJ is offline
It fits - no sheet metal cut.
More pics here - http://www.chaserace.com/exhaust/exhaustwagoneer.html
[ April 13, 2005, 02:13 PM: Message edited by: DieselSJ ]
-99 XJ Limited.
Old 04-13-2005, 09:48 AM
JeepsAndGuns's Avatar
Now what are you gonna do about the heater and blower motor. I noticed that they are gone and the down pipe now sits there.
Old 04-13-2005, 12:58 PM
Crazy_Jeepman's Avatar
Sloppy Shifter
While I was looking at the 6.2/6.5 as a swap, but decided against it. I want to say that looks like a real good job on fitting it into your rig! I hope to get started on the Cummins swap soon and will post pictures. Hope it turns out as nice as what is shown here. As far as the Hydro Boost brakes go, you would be foolish spending 700.00 on it. Caddy Eldorado are almost a direct bolt on unit, GM 1 tons can also be used with minor mods to the push rod. I have 2 such units and I will be using on my J10 and on my Chero
Old 04-13-2005, 01:44 PM
ohioj20's Avatar
Good job on the 6.5 TD!! What have you come up with for heat though?
Kenny
Old 04-13-2005, 01:46 PM
ohioj20's Avatar
Kenny
Old 04-13-2005, 02:50 PM
Simple Kind of Man Simple Kind of Man is offline
don't want to step on anyones toes but there are stand-alone heat/air units that fit under the dash. I think Bob Davis has one in his stepside J10.
\'81 j10, 360, 727,208
6.2/6.5 Chevy GM diesel owners... Karl Streich Diesel Swaps 23 05-31-2009 12:02 PM
Flexplate shims - Chevy diesel and AMC TH400 ninjaneer Diesel Swaps 11 01-04-2007 09:03 PM
Diesel Engine to replace Chevy 350 dmangel19 Diesel Swaps 1 05-05-2005 06:25 AM
A little snag in the diesel swap emissions WA state DieselSJ General FSJ Tech 51 03-18-2004 10:16 AM
