Originally posted by The PIG Smith
1973 J4800 4BTA Cummins swap
Jason in the Mountains
1978 J10 LB,OE 4-speed,4:10's,4BBl,and just 85K(daily driver)
1988 Grand Waggy 8" lift 35" A/T's (under construction)
1984 CJ7 12" lift 39" Iroks 1 tons
1979 Cherokee Super Chief (under construction )
1974 J-10 LB Buick 455 BB 4" lift 33" BFG tires
1973 J-4800 LB plow truck 7" lift 255/85/16 LT Truxs MT's
Originally posted by ChevelleguyPumps, Gen sets, compressor engines should work, you would just have to get the injection pump set up for automotive use.
Gen sets and Compressor engines have different govenors as well they typically dont have an AFC air fuel controll system for low boost fueling under load. this system is what compensates with additional fueling to keep the motor running when you let the clutch pout and increase the load against the engine off idleCherokee S Chief Widetrack W/ Cummins 4bta Diesel, 91 dodge intercooler, hy35/9, AC NV4500/D300 3.54's Ploks 4" BJ's w/ 33's, scout 33 gal fuel tank ( Sold, to a good fsj home)
AMC 401 supporter
GO UM Montana Griz
Does that van have a hydroboost in it?
Originally posted by The PIG SmithI am a member there also.
I would also ask that you make some postings over at the http://messages.jeep2diesel.org/ forum also.
It was down for a while and is now back.
The activity is slow, but is building as folks know the site is back and folks start to participate.-87 Grand, 6.5L diesel, MHI TE06H turbo, Water/air intercooler, Art Carr 700R4, CS-130, hydroboost. 21/24mpg, dead 229 [Custom 242 on the way]
-99 XJ Limited.
Finally found a donor 6BT to take front drive parts off of and a/c mounts. I'll post some pics tonight.Jason in the Mountains
New pics!!!!!!!!
Well after a long winter I able to get the van into the garage and work on it. I have the motor out now and here are the pipcs of the 6BT parts I found.
Originally posted by skeletorman that garage must be huge to be able to fit a frito lay truck in there.Jason in the Mountains
Say... what's the lug spacing on those rims, and what year van is that? Those look like they might be a swap for the Jeep dually spit rims. Prolly a metric pattern though...*** I am collecting pics and info on any factory Jeep Dually trucks from the J-Series at the new Jeep Dually Registry.
Originally posted by ElliottSay... what's the lug spacing on those rims, and what year van is that? Those look like they might be a swap for the Jeep dually spit rims. Prolly a metric pattern though...Jason in the Mountains
These are the motor mounts. I plan to cut them down 3.5" inches and weld them onto the frame of the GW. The best thing about using the factory motor mounts they're made of 1/2 plate steel. With the crossmember that comes with it, should make a strong mount for the motor.
The mounts are liquid filled to reduce vibration.
The crossmember.
First test fit of motor.
