Unless I just turned it off recently you need to pump the pedal and let turn over for a few seconds. It could take as much as half a minute or longer to get enough gas to start. I have already changed out the fuel pump thinking the diaphragm was leaking. Worse when it is warm or hot outside. Did it before and after carb change out.
Your thoughts?
Your thoughts?
