Hi
in the process of planning for my 5.3 / 6L80 swap into the 1977 Chief. Trying to plan my fuel system. I want to use the original tank...
So, does anybody have a tank available to give me a total depth measurement from the top of the tank to the bottom of the tank? This would be best with the pickup removed.
Why? I am planning to find a GM sending unit that I can adapt to this spot. I plan to have the tank cleaned and coated. The company says they can add/modify the opening if I find a module that will fit.
I currently have 2 tanks.. and plan to remove the original dealer installed 25 gallon tank in the spare tire area. Is it worth anything? I have the switching stuff too. It works fine.. but it is 40 years old and should be cleaned well
