In the spirit of full disclosure, I am going to track the true cost of an engine swap.
I suspect many have no idea how much it really costs.
Something to consider if you choose to venture down this road.
It's way more expensive than I thought. Parts with cost will be listed (excluding shipping).
Total will be updated as I go.
Note: I am buying a lot of "new" parts... One could save monies by using recycled parts.
Total As Of: 8/19/20 - $ 12,283 [So Far]
$4,078 : 2018 Yukon 5.3 Gen 5 / 6L80. Harness/pedal and ECU included
$ 628: NOVAK Dana 300 to 6L80 adaptor
$ 36: Trans Mount - Novak
$ 224: LS Engine "Bolt On" kit - BJs Off Road
$ 151: Corvette PS pump / pully
$ 212: ICT Billet PS bracket kit ( need to add PS to Acc drive )
$ 28: ICT Billet oil cooler block off plate
$ 610: Gen 5 FJS radiator - BJs Off Road
$ 530: Holly in tank returnless fuel pump module (12-131)
$ Free: Dana 300 [ donated from a friend ]
$ 340: Program ECU/bracket (Swaptime)
$ 80: Accel Pedal ( Camaro )
$ 550: Modify Gen 5 harness (Swaptime)
$ 45: 100" serp belt
$ 16: Gen 5 vacuum port block off plugs
$ 29: ICT Billet water block port ( for sending unit )
$ 44: New sending unit for tank - BJs Off Road
$ 20: New speedo cable (non cruise) - BJs Off Road
$ 53: ICT LS to LT mount adaptors
$ 292: Gas tank cleaning / coating / rework
$ 58: Heater Core cleaning and reseal
$ 291: 2017 Camaro Fan - PWM
$ 113: Condenser and Evaporator clean out and test
$ 65: Fuel Fill hose
$ 106: Borla muffler
$ 25: PS cooler
$ 38: Trans cooler
$ 75: Lokar shift linkage kit for column to 6L80
$ 65: Fuel Filter
$ 40: Fuel Line / fittings
$ 42: Misc hardware/fittings
$ 185: Shocks / damper
$ 53: Filler neck clean/coating
$ 57: 6L80 Trans shift adaptor - Lokar
$ 30: Dana 300 CJ shift boot
$ 41: Temp and oil sending units [AMC]
$ 830: Hydraboost with Vette master cylinder and adjustable prop valve
$ 18: Mics hardware - clamps
$ 23: Power steering filter
$ 74: Dana 300 CV front output yoke with bolts
$ 300: GOR / inner fender blast and powder coating
$ 680: Rear double/double Carden driveshaft with Dana 300 / Dana 44 CV output yokes with bolts.
$ 33: Remote PS reservoir
$ 65 Cold Air intake kit
$ 24 MAF sensor mount
$ 86: MAF sensor
$900: Stainless exhaust and engine mount welding
Still Need to get :__________________________________________________ _________________
Ac block and AC lines to adapt SJ system to GM pump.
AC charge
