Fuel injecting my '88 Waggy (lots o' pics)
  • Probesport
    • Apr 15, 2015
    • 155
    It's one I had from another project. 1950s era Cadillac or Oldsmobile
    Ken S.
    Megasquirt EFI
    : Heated Seats : Blower fix : Driving light brackets : Shorty headers : Coil Packs : Electric Fans
    • Achilles
      • May 12, 2004
      • 1177
      It is very unique.
      Life happens while you are making plans...............
      • Probesport
        • Apr 15, 2015
        • 155
        It may be unique in the Jeep world, but it's quite common in the Hot Rod scene.
        Many reproductions out there too at not much cost.
        Ken S.
        Megasquirt EFI
        • j10jim
          • Jan 11, 2003
          • 605
          All you guys that can put non smog legal FI on your cars....
          Only option for us in Calif is Howell
          1980 J-10<br />Rusty\'s 4 inch lift<br />2 inch body lift,<br />35 in Xterrains on J20 axles<br />4:30 gears<br />Detroits<br />In-Cab cage thru the dash
          • yossarian19
            • Nov 13, 2016
            • 402
            Or be like me, take a Saturday and drive to Oregon for a '75.
            • Probesport
              • Apr 15, 2015
              • 155
              There is no reason you couldn't make a Megasquirt pass smog, it would be some work but its as configurable as anything that exists.
              Ken S.
              Megasquirt EFI
              • babywag
                • Jun 08, 2005
                • 10288
                Not 100% accurate. You can install an aftermarket system or modified OEM system.
                The kicker is you have to visit a smog referee, if everything is installed/working correctly and it passes testing he will sign off on it.
                While not specifically FSJ CA smog legal, the MSD Atomic EFI does have an EO# for chevy vehicles. Any sensible smog referee would likely allow it.
                • grand_wag_85
                  Murphy's Law Poster Child
                  • Dec 03, 2003
                  • 10719
                  Curious what the cost has been so far for the MS?
                  '88 GW
                  '77 J10 Golden Eagle 401
                  • yossarian19
                    • Nov 13, 2016
                    • 402
                    Guys you could definitely make megasquirt run clean enough for a sniff test but there is *no way* a smog referee would let it pass without an E.O. number for that specific year, make & model. Definitely get it in writing that a ref would pass it before starting work.
                    • Probesport
                      • Apr 15, 2015
                      • 155
                      That's a tough one. I actually started with a GM ECU style kit. The MS was built from spare parts and such so I really cannot say.
                      If you went my exact route for EFI , I'd say you'd be in it for ~$1500 but I have some unnecessary expense as I started with a kit.
                      Ken S.
                      Megasquirt EFI
                      • Achilles
                        • May 12, 2004
                        • 1177
                        #41
                        You have any pictures of the O2 sensor mounted in the y Pipe?
                        • Probesport
                          • Apr 15, 2015
                          • 155
                          #42
                          I don't think that I do. I'll take a look though.
                          Ken S.
                          Megasquirt EFI
                          • yossarian19
                            • Nov 13, 2016
                            • 402
                            #43
                            $1500? Hmm.
                            DIYAutotune sells a carb-to-EFI kit, sans throttle body, for $829 assembled or cheaper if you don't want / need fully assembled & accessorized. Not an amazing deal when you compare it to a Holley Sniper but then, MS will do things the Sniper won't (crank trigger, multiport, etc)
                            • Probesport
                              • Apr 15, 2015
                              • 155
                              #44
                              I was referring to the cost of the entire project, start to finish. Not just a portion or just the MS itself.
                              I am running an MS2V3, from parts/kit - that portion is only a few hundred.
                              Ken S.
                              Megasquirt EFI
