09-05-2012, 09:11 PM
2000 up Dodge Durango / Dakota power seat, Now plan B!!!
09-05-2012, 10:21 PM
I think I have figure out which wires belong to which switch on both of the switch harness. I think I am going to test it out on the durango power seat bracket first so that i do not destroy the wagoneer power seat bracket.
09-06-2012, 05:22 AM
The drivers side on mine, I did the surgery route and was way simple, I'll try and get a pic sometime for ya. The pass side I still haven't mounted but I think a simple bracket can be made to hold it.
73 j-4000 "buttercup"-SOA 36's 4 door cab
78 wagoneer choptop-SOA 36's, 6 point cage, blah blah blah
09-06-2012, 11:36 AM
This is what I ended up doing. Took the easy way out!!!
Did the surgery. Trying to figure out what I am going to do on the passenger side. Have a few ideas.
09-06-2012, 04:11 PM
Yup pretty much just what I did, it just fit so good like that. With very little effort.
09-06-2012, 05:30 PM
Yep it fit really well.
02-12-2014, 08:50 PM
Anyone know if the rear seat of a durango will work in a wagoneer?
1979 Wagoneer QT 360 4" BDS Lift
1979 Cherokee Chief QT 360
1968 Jeepster Commando 4" HC Lift
2006 Honda Shadow Aero
1986 Honda XR600R
1984 Chevy 3500 Box Truck
02-12-2014, 10:34 PM
Great post. Cant wait till I find mine. Do you use the GW Mount ? Do I use Non powered seats and loose the rail system ?
Thanks
02-13-2014, 07:57 AM
Thanks
Both of us used the same setup, power drivers seat and non power pass seat. The rails and all unbolt from the durango seat and basically bolt on to the power portion of the wagonner bases. I say basically bolt on cause I think I had to drill out a hole or two on mine to fit together. It was a pretty easy job.
02-13-2014, 10:36 AM
Thanks for the info, trickc
02-13-2014, 03:09 PM
Anyone know if the back seat from a Durango will replace the back seat in a Wagoneer?
1986 Honda XR600R
02-14-2014, 08:02 AM
I'll try to get you some measurements of the durango back seat, I don't know that it will because the wag seat has that little cut out on either side for the wheel hump.
02-14-2014, 01:31 PM
Durango Back Seats
I tried one when I picked up my front seats and it didn't fit. Too long and didn't have the fender notches. I would love to know what would work though.
Certified Novice Mechanic...
89 Grand Wagoneer (AMC 360/TF727/NP229)
A work in progress!
Thread Tools |
Display Modes |
