What 4.0 Head do I need to upgrade my 258. I want to improve mpg and power. I am open to a V8 upgrade as well. Any insight will be greatly appreciated. I would like to hear both sides pros and cons. Thank you!
4.0 Head or V8 conversion?
Originally posted by Dmntxn77I think anytime someone looks for a mpg improvement on a FSJ, they are just setting themselves up for disappointment. As oppose to engine upgrades, your best first step might be gears though.
Are you set on fuel-injecting a 258 with a 4.0 head, system, and custom tune? I assume that's why you posted this in the EFI forum. You'd get more replies in General Tech, though. Oh, and a V8 conversion on an I-6 FSJ is more complicated than you might think - it's not strictly a drop-in deal, even if you want to swap in an AMC 360.
If fuel economy is your biggest goal stick with the 258 and put a '91-'95 4.0 head on it. Upgrade to a 2150 carb with the factory 4.0 manifold/header or an aftermarket 4.0 header with a better flowing exhaust and upgraded ignition. All of that will also give you pretty big power boost. Fuel injecting it is a decent amount more work, money and not much if any improvement over the other upgrades I suggested.Originally posted by Ristow
i bet it was Simon....
IMO your best route to maximize fuel economy is a complete '91 or later 4.0L transplant. That will give you a lot more power on the highway, and has the potential for the high end of what these vehicles can do, mpg-wise.
The design of the 258 is not good for efficiency. The stroke is too long compared to the bore (undersquare) and this will always affect the mileage characteristics of the engine. The 4.0L has a much shorter stroke and a larger bore than the 258. Look at some modern engines, and you'll see that they all have an oversquare design, with a short stroke.
The 4.0L also has a much more modern head design, and the Mopar multiport fuel injection (MPI) that comes with the 4.0L is excellent. And there are bunches of them around - buy a complete rusty XJ donor and transplant what you need, then scrap the rest.
<added> As mentioned above, there are quite a few differences between the 360 trucks and the 258 trucks. You may as well go with a MPI Chevy conversion as an AMC 360. The only thing the 360 gives you is the transmission will bolt to the new engine, but everything moves around - the radiator and core support are different, engine mounts are different, driveshaft lengths change, transmission and transfer case move in the chassis ... you may as well go Chevy and get a modern engine design and cheap-and-modern MPI in the bargain.
But nothing needs to move for the 4.0L swap. All your effort will go in to connecting the new systems.Last edited by tgreese; 07-18-2012, 06:23 AM.Tim Reese
Why mess around with a half step ? go for a 4.5+ stroker IMHO.
(Less farting around with filling head holes .. you have the 258 crank, pick up a 4.0 and put all together)
Originally posted by ChiefBigBWhat 4.0 Head do I need to upgrade my 258. I want to improve mpg and power. I am open to a V8 upgrade as well. Any insight will be greatly appreciated. I would like to hear both sides pros and cons. Thank you!-----------------------------------------
Home of ADHD project list
1977 J-10 Honcho 360-T15-D20
Keep that inline six. I say this because of two things:
One, you have very low end torque that rivals that of the Ford 300 six.
And Two, there are too many AMC 360s on the road, a 258 is better
With that said, a 4.0 head swap sounds very great with benefits that make it better than swapping in a 360. Unless you want to build an OMFGSUPERFAST1000MPH engine, inline six is your engine.CJ
[/COLOR][/SIZE] -1985 Ford LTD Country Squire "Rarity" - 302/AOD
Originally posted by Mr CartsI was thinking of going the other way 360 to 258. What are the difference in the mounting of the drive train?Tim Reese
FWIW - I have an '82 Cherokee with the inline 6/5 speed combo and was looking at upgrade options. The biggest requirement to me is that it is a modern, fuel injected design. (and since I live the the lovely state of California, it had to pass smog). I considered a few options:
4.0 head and fuel injection on my current engine. Since my current engine has over 250k miles on it, I need to include the cost of rebuilding it. Figure $1,500 ~ $2,000 by the time I buy the head, fuel injection, computer, rebuild kit, and necessary machine work. I'll end up with a torquey six that should produce around 175 ~ 180 hp. (up from the stock 110). If your engine is in good shape you could probably do this for a lot less money.
4.0 HO engine with my 258 crank for a 4.5 stroker. From what I've seen other do on the 'net, this should cost around $2,000 ~ $2500 and produce around 225 hp. I've heard that the T5 tranny I have is marginal and may not like doubling the hp.
AMC 360 swap. I said "modern fuel injected engine", remember?
Chevy 5.3 LS engine/4L60E overdrive automatic. Chevy made a zillion of these and you can pick them up for $1,000 ~ $1,500 on Craigslist. Novak and others make engine mounts and adaptors. I think I can make it happen for $2,500 ~ $3,000 (at least that's what I'm telling the wife) and will get 285 hp (or more with some easy mods), and as good or better gas mileage than any other combo along with Chevy reliability. To top it off, there is a couple of great writeups on this forum from others that have done this, and they love the result.
So that's my current plan (which could change, but I think this is the one I will do) - drop in the Chevy combo.
Just my $ .02, but I had the same questions, and this is what I came up with.
Originally posted by CJ the noisemakerKeep that inline six. I say this because of two things:
With that said, a 4.0 head swap sounds very great with benefits that make it better than swapping in a 360. Unless you want to build an OMFGSUPERFAST1000MPH engine, inline six is your engine.Austin
Originally posted by rustywagoneers_comi am not an addict, i can stop anytime.
I did the 4.0 head on my old jeep with mpfi- no noticeable mileage gain but lots of power. I just recently added mopar mpfi to my 258 without the head swap. Same power but again no mileage gain over the stock carb. With both setups i got 14 mpg city and 17 hwy. Thats with 3.31 gears and a t176 and t5 respectively. I think your best bet would be a complete 4.0 or better yet a stroker and of course the efi to go with it. This will get you the most power and possibly a gain in mileage but i wouldn't expect much. The six just has to work too hard to move our rigs.For Sale Custom built reproduction Rhino Grilles http://www.ifsja.org/forums/vb/showt...24#post1676924PM me for details or email [email protected]
1982 Cherokee Chief 258 6 cyl, AX-15, NP208, mopar mpfi, hydroboost brakes.
1983 Jeep Cherokee Laredo 258 6cyl*SOLD*
The 96-99 heads are basically the same as 91-95 heads (they flow the same) with a few minor differences - and I think the exhaust manifolds need to correspond.
The 4.0 head swap can be done cheap and you can modify your original carb manifold to work with the 4.0 head, making it even cheaper.
For mileage, a v8 swap wouldn't be cost effective IMO, even with a v8 that could get 20mpg, it would take you a very long time to make your money back. Power, on the other hand, knows no spending limit!!
With all that said, what gears do you have - because as said earlier, that migh be a better first step.Last edited by backroadin'; 07-18-2012, 06:55 PM.1973 Wagoneer, 4.6L Jeep inline 6 stroker, t176/d300, offy dualport w/ quadrajet, pertronix, flowmaster
"Roads? Where we're going we don't need roads." -- Doc Brown https://forums.ifsja.org/images/smilies/cool.png
"When this baby reaches 88 miles per hour, you're gonna to see some serious shhttps://forums.ifsja.org/images/smilies/eek.pngt!"
Originally posted by backroadin'...even with a v8 that could get 20mpg, it would take you a very long time to make your money back.CJ
