Old 11-30-2000, 12:25 AM
bill49417
Posts: n/a
Smile
Morning, after removing the snowplow from my J20, the frontend now sits higher than the rear. I plan on putting 2" lift blocks on the rear to put things back on an even keel so here's my question. Do I need to worry about the differential angle and install "wedge shaped" blocks or is 2" minimal and square blocks will work fine? Thanks and remember "Don't crush them, restore them"
87 J20
360, DANA 60,
38,000 MILES
Old 11-30-2000, 02:32 AM
Manhattan Manhattan is offline
My guess is that you'll be fine with no degree shims or degreed blocks. I'll bet that your springs have sagged enough that the lift will get you just back to factory height or little over.
I installed 3" springs on my '88 GW with no shims - and no problems. The net gain was 5.5". I can assume, if they where really 3" springs, that my factory springs had sagged 2.5"
If I had added 2" blocks, I would have been right about where the GW came off the assembly line... no shim needed.
a.k.a."Bushwood" '88 G-Wag' New 360, 3" Springs, 31" ATs, Custom Roof Rack, 2.5" Dynomax Exhaust... rest stock.
Old 11-30-2000, 03:19 AM
You should be fine with a 2" block (0 Degree)...did you add leafs up up front to compensate for the plow? Is that why it's higher in the front? Just curious...
Todd
78 Wagoneer, "River Beast"
360/TH400/QT
Dana 44's locked w/ 4.89's
39.50x15x15 Super Swamper TSL's
7" SOA in front-7" Rear Shackle Inversion Mods
4" Skyjacker Softride
3" Trailmaster Bodylift
My FSJ site: http://www.geocities.com/spazz4life
My E-mail: monster_fsj@hotmail.com
"If you can't stop...SMILE as you go under!"
'93 3/4 ton 4x4 Suburban...a.k.a. "FSJ Hauler"
Old 11-30-2000, 04:34 AM
bill49417
Posts: n/a
No, no add a leaf in the front. It has the 8400 spring pack on the front and rear. The spring packs are huge. Needless to say the ride is really rough. Already sits so high it just bearly fits in the garage. Now thats a truck!
87 J20
360, DANA 60,
38,000 MILES
DON'T CRUSH EM, RESTORE EM!
Old 11-30-2000, 06:07 AM
Adamstrator
Posts: n/a
No problems with a 2" block
Old 11-30-2000, 07:59 AM
thanks Bill.... I hear ya about fittin in a garage! I am in process of building my garage and the builders thought I was insane asking for a 10' drive-in with a 12' ceiling until they saw 'River Beast'...I clear my carport by .5" with 31's... my 39.5's are waiting in my friends garage until I 'm done with my rig!!!
Todd
360/TH400/QT
