Old 06-09-2021, 01:28 PM
bluehwy's Avatar
bluehwy bluehwy is offline
Guru Help on Fenders
I have a '79 Wag that is in the body shop. Only thing holding up progress are the two front fenders. Can't get a fender patch anywhere. Been looking at used Jeeps. Are the fitments for mine '71 to '83? I found an '88 and am trying to figure out if they are a match.
Been searching throughout the forums but am not finding that info. Thank you for your help!
Previous: 1989 or 90? Maybe a 91... Grand Wagoneer
Current: 1979 Wagoneer, 1989 Grand
"Well I've been down so God damn long! and it looks like up to me..." Furry Lewis (but Doors version)
Old 06-09-2021, 03:03 PM
Outer sheetmetal is all ~same through entire run.
difference is how many and where holes for trim are.
70's rigs have line of holes for stainless trim
'84-'91 have crapload holes for woodgrain.
for example my 1988 has 1965 fenders on it.
I have a lower rear section of a passenger fender and a possibly a driver fender if you're after lower rear patch panels?
Cannot remember if I still have driver fender laying around?
Old 06-09-2021, 04:07 PM
80Limited 80Limited is online now
Bjs has patch panels but they are spendy.
https://www.bjsoffroad.com/Fender-Pa...91_p_2280.html
If not I have 4 fenders I was going to piece together to make 1 good set. Let me know. 1 set from a 76 the other from an 80.
Old 06-09-2021, 05:12 PM
goldhammer's Avatar
Some years had wrap around marker/turn signals, so more/bigger openings by the headlight. Want to say around late 60's egg crate grilles.
Art
ASE Master Collision Tech
Old 06-09-2021, 08:40 PM
bluehwy's Avatar
@babywag Thanks! All body work is complete except for front fenders. Picked up an '89 Waggy today.
Old 06-09-2021, 08:44 PM
bluehwy's Avatar
Awesome! I ordered them from BJ's in January but... Fauci's buddy got loose. I'll hit you up in the next couple of days. Have to go by the body shop and snap pictures of exactly where they need to be cut. If you're willing maybe you can cut just those spots and keep the rest.
Old 06-09-2021, 08:47 PM
bluehwy's Avatar
So picked up an '88 today and it's in such good shape I don't want to start hacking it (and wasn't sure they'd fit my '79).
Old 06-09-2021, 08:55 PM
bluehwy's Avatar
I think that's the exact portion I need. If you're willing to part. Need to verify with body shop. Not sure it they were able to fix the inner wheel wheels either. Seemed like they were pretty bad where they connected to the fenders but the guy that was doing that work quit the body shop. You and goldhammer are awesome! Thank you!
Old 06-10-2021, 09:48 AM
I saved it just for someone who needs a patch.
Solid SoCal original fender just some surface rust.
Shoot me a PM with your cell# if want a txt with pics.
or email address and I can send that way as well.
Old 06-10-2021, 10:16 AM
It's the "cheese grater" grilles that have a big hole in the leading edge of the fender, IIRC. '70-73 Wagoneers.
http://jubileejeeps.org/faqs/fsjgrillesrevisedflint.jpg
All the others should be ok if you can patch and move the little holes for trim to match your originals.
Try car-part.com
There's also this place https://montanaoverland.com/contact-us.html which may be within driving distance of you.
Old 06-10-2021, 09:28 PM
bluehwy's Avatar
Thank you! I will look all of that up. My fenders are in super great shape except for just one (the same on each side) spot. Almost hard to even tell I needed any work at all. Especially $325 to $475 per fender!!! Insane!
Try car-part.com
Old 06-10-2021, 09:37 PM
goldhammer's Avatar
Thanks for the correction Tim.
Art
Old 07-29-2021, 01:33 PM
bluehwy's Avatar
Thanks again babywag!
[IMG]Unknown-17 by Chad O'Malley, on Flickr[/IMG]
Old 07-29-2021, 01:35 PM
bluehwy's Avatar
[IMG]Unknown-16 by Chad O'Malley, on Flickr[/IMG]
Old 07-29-2021, 01:36 PM
bluehwy's Avatar
[IMG]Unknown-3 by Chad O'Malley, on Flickr[/IMG]
Old 07-29-2021, 01:37 PM
bluehwy's Avatar
[IMG]Unknown-2 by Chad O'Malley, on Flickr[/IMG]
Fiberglass Fenders localfiend General FSJ Discussion 3 06-29-2013 11:59 AM
Question about front fenders?? Phaydon General FSJ Discussion 2 07-23-2011 07:51 AM
Tire size ? for M715 bed &front fenders HOOT General FSJ Tech 17 03-05-2011 10:47 PM
M715 fenders, SOA & WT axles on a Waggy AKAMC General FSJ Discussion 4 06-11-2009 10:23 AM
Any value/problems getting rid of inner fenders on J10? EL Grande Honcho Off-Road FSJ Tech 3 01-27-2009 03:36 PM
