Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Wanted
Old 08-23-2020, 12:09 PM
BA_051 BA_051 is offline
74-79 Drivers door release mechanism
Well it seems my door is a bit tight with the aftermarket weatherstripping and today when i tried to exit my truck, the door handle broke off...
I need the door release mechanism that the handle bolts onto and it attached to the door. Not sure if all years are the same.
If someone is parting out a driver and passenger door, I will take the lock mechanisms and release mechanisms as well.
My doors do not have the loop on the jamb, they have the cup with the notch... hard to describe. I will get pics of it.
1974 Jeep J20, gladiator grill, 6BTA JWAC cummins, HX55, 4in exhaust to 5in stack, nv4500/ford np205, 14b kingpin axle, 14b rear axle, 4.56 gears, 40x13.50r17's on 17x10 mags
Future mods:
G56 6 speed with dual disk clutch
Vintage air AC and Heat underdash combo unit
Old 08-23-2020, 04:39 PM
Driftwood's Avatar
Here's some pics that may help.
I am replacing my Pre 1979.5 right rear door with a door from a 1983.
Right rear passenger door swap.
1979 Wagoneer
Old 08-23-2020, 07:29 PM
Yes, that is the info I was looking for... I have the pre-1979.5 striker plate and lock mechanisms.
If anyone is parting out a driver and passenger front doors, I would pretty much want the striker plates, lock mechanisms, and lock release cranks.
I was able to use my OA and a #1 tip and successfully welded the splines back onto the base portion of the release mechanism, but I am unsure how long it would hold... I did beef it up with extra material and used my dremel to clean up the splines.
Future mods:
Old 08-24-2020, 09:59 AM
AMC-COMMANDO's Avatar
AMC-COMMANDO AMC-COMMANDO is offline
If you can post up pics of exactly what you need, I may have them from a 75. I know the stiker plates but unsure exactly what the other parts are.
1975 J20
1972 Commando
1962 CJ3B U.S. Navy
1971 Hurst Jeepster
Old 10-15-2020, 08:37 PM
I do not have pics being the door is assembled on the truck. I may pull it apart to clean it this weekend. If I do, I will get pics of what I’m looking for.
I need the parts you swapped from your pre 1979 door into the 1983 door. From a front door, not a rear door though.
I need the strikers...
The lock assemblies are screwed to the inside rear of the door and engage the striker to hold the door closed. It is held in with 3 tapered screws that face the striker when closed.
The remote assembly. It is screwed to the door with 3 screws and has a linkage that attaches to the lock mechanism assembly (described above) and the interior door handle slides on and is held in place with a single screw in the center.
Future mods:
Old 10-18-2020, 04:31 PM
I found this over on FSJ network (I think). I need the one on the left. I also need the other part that goes to the interior door handle with the long rod/bar on it.
Needing the drivers side and passenger side setups.
Future mods:
what did u do to your jeep this weekend NCOfab General FSJ Discussion 3523 02-17-2021 01:48 PM
How to remove and clean door lock mechanism? YoungClayB General FSJ Tech 10 02-07-2008 07:37 PM
Registered Numbers So Far 2nd Day East Coast FSJ Invasion 50 06-02-2005 01:00 PM
Driver's seat belt buzzer obsession -- some info Matthew W. Woodruff General FSJ Tech 2 08-10-2003 04:15 PM
Driver's wiper arm is out of control. illegalFSJ General FSJ Tech 9 10-18-2002 07:00 AM
