Old 01-01-2020, 01:03 PM
wincher's Avatar
wincher wincher is offline
To Do List for my 1979 Chief
Happy new year to all of you!
Is it allowed to ask my questions to different themes in one Thread?
It would be simplier for me to follow your answers or links to former contributions.
regards.
wincher.
78 chief 360amc
02 wj 4.7HO Overland
Old 01-02-2020, 12:51 PM
You can do whatever is easiest for you. We're not horribly strict around here.
Old 01-03-2020, 12:27 AM
FleetFox's Avatar
FleetFox FleetFox is offline
Fire away.
Fleet Fox
Old 01-03-2020, 10:29 AM
wincher's Avatar
Thank you !
and excuse my poor englisch.
I make use of the 1979 Technical Service Manual
Axle: renew the lower and upper ball stud. Got the parts from the previous owner
The snipping pics from the TSM doesnt work here..
78 chief 360amc
Old 01-03-2020, 10:31 AM
wincher's Avatar
Carburetor: bought a nearly new 1406 edelbrock. but I am a victim of a ebay scammer
paid for it but no shipping of the carb.!! Happy new year!
visited the police station yesterday...
have to check my carter AFB 625cfm carb
Ignition Timing:
have to check the timing. Strobe lamp is availlable.
(My grandpa, father and now my brother have a garage since the 1960 years...)
Timing 10 degrees at idle with the barrel number 1?
Change to a MSD Ignition??
Vacuum Unit?? Distributor ??
No Kickdown
No wire from the Detent Switch to the transmission existing.
And adjustment availlable: Pedal - detent switch
Adustment of the gear linkage.
gearshift lever doesnt fit to quadrant dial. with lever max to right transmission is in 2 and not in 1 gear.
Fuse panel
looks awful and not original.
with wore patched fuses...
mine looks different to this in the manual
Exhaust Manifold
probably broken an the right bank over the heat valve.
prabably the screws get over tighten ..
A friend has maybe a intact manifold an knows a good welder
Fresh Air
No Bowden cable existing. and no duct control switch.
78 chief 360amc
Old 01-06-2020, 11:22 PM
FleetFox's Avatar
Tschuss!
\F
Old 01-07-2020, 04:38 PM
Here is my opinion.
I have a general rule when I buying a project:
1) make it run.
2) make it drive.
3) make things work.
4) make it reliable.
5) make it look good.
With that in mind and looking at your list:
1) Carburetor: have to check my carter AFB 625cfm carb. Rebuild this. There should be a number stamped on the horn that will tell you exactly what it is. There is a TOOOOooooooon of information on AFBs on the interwebz. It's a good carb and can run well on a 360. Rebuild it, put fresh gas in it, stick it on top, and try to get the truck to start.
http://www.carburetor-blog.com/carter-afb-carburetor/
2)Ignition Timing: Timing 10 degrees at idle with the barrel number 1? Yes, set it at 10 degrees with the engine idling and no vacuum signal to the distributor. Take the vacuum line off the distributor and plug the vacuum line (DO NOT FORGET TO PLUG THE VACUUM LINE). Set it to 10.
Change to a MSD Ignition??No, leave it a factory setup if it works
Vacuum Unit?? Distributor ?? Are you asking what these are of if you should change them? Don't change from factory parts if you can. Stay stock.
3) No Kickdown
No wire from the Detent Switch to the transmission existing.=I assume the switch is there, though? if so, you can make your own harness. But get it running first (carb and timing first).
Get the wire first
4) Adustment of the gear linkage. gearshift lever doesnt fit to quadrant dial. with lever max to right transmission is in 2 and not in 1 gear.
=this sound more like loose/sloppy parts. Put it in park and wiggle the shifter. Find the slop and try to fix that.
5) Fuse panel looks awful and not original. with wore patched fuses...
=Post pictures. This may be a killer. This may end up being the first job after you rebuild the carb and try to start it.
6) Exhaust Manifold probably broken an the right bank over the heat valve.
probably the screws get over tighten .. A friend has maybe a intact manifold an knows a good welder
=Ignore this for now. Get it running/driving first. A broken manifold is highly annoying and fixable but get to the other stuff first.
7) Fresh Air No Bowden cable existing. and no duct control switch.
=Ignore this for now. You can get to this later.
8) Axle: renew the lower and upper ball stud. Got the parts from the previous owner
=Do this after it runs and drives. This is important but make sure it runs and drives, first. This is a long (but not hard) job.
=nope. the TSM is scanned in a way that makes it hard to post pics of it. If I need to post a picture, I take a screen shot on my laptop, paste it into Microsoft paint, save it as a .jpg then post that.
Old 01-07-2020, 04:44 PM
SJTD SJTD is offline
You're missing a step:
0.5) Make it past the wife.
Sic friatur crustulum
Old 01-07-2020, 04:53 PM
HAHAHAHAHAHA!!! PAINFULLY TRUE!!!! LOL!!!
Old 01-07-2020, 10:49 PM
FleetFox's Avatar
Post some pictures of the transmission linkage. I just did mine and probably can tell what's missing or warn out.
other than that I believe Rang has given some good advice.
Fleet Fox
Old 01-08-2020, 04:23 PM
wincher's Avatar
1) make it run.
It runs. Have done a testdrive before selling the jeep
2) make it drive.
kickdown ist the first.
The linkage looks worn out or only a loose nut. unfortunately i cant visit the jeep since Christmas..
correct ignition and carb setting.
maybe the 33" tires, the car roor lining, ..
Carb is a 9637SA 0205. see the separat thread
Thanks for the link to Carter.
trying to fit so small jps for uploading.
78 chief 360amc
Old 01-10-2020, 01:01 PM
wincher's Avatar
What on earth is my mistake?
Open a jpg with irvanView, change the size to 365kb (by percent from original)and save the pic.
In Windows explorer the size is now 365 kb ..
The max size for jpg attachement is 488,3kb.(Attachment key)
try to upload the file and become a upload error :
exceeds forum qouta by 365kb...
78 chief 360amc
Old 01-10-2020, 01:10 PM
Yeah, It's kind of a pain to post pictures. Here are 2 threads with different ways of doing it:
http://www.ifsja.org/forums/vb/showthread.php?t=185569
http://www.ifsja.org/forums/vb/showthread.php?t=170876
Old 01-10-2020, 01:40 PM
wincher's Avatar
thanks ,
that means no direct upload from hard disc to the forum.
78 chief 360amc
Old 01-10-2020, 01:41 PM
wincher's Avatar
linkage
78 chief 360amc
Old 01-10-2020, 01:45 PM
wincher's Avatar
78 chief 360amc
Old 01-10-2020, 01:54 PM
wincher's Avatar
sorry for the big file size....
78 chief 360amc
Old 01-10-2020, 01:59 PM
wincher's Avatar
78 chief 360amc
Old 01-11-2020, 02:10 AM
wincher's Avatar
Mine has no bushing between seletor lever bracket and the lever.
or the lever bracket is wrong mounted . Frontside with bushing to backside..
Maybe to much clearance without guidance here...
78 chief 360amc
Old 01-11-2020, 07:17 AM
Love the modified fuses! at least its better than the .22 bullets I have seen used!
76 Chief 360/auto bolt into an 80 J10? FMSINC General FSJ Tech 14 02-17-2016 04:05 PM
1979 Jeep Cherokee Chief backfires Brody93 General FSJ Tech 9 01-23-2012 09:37 PM
4.0 swap in a 1979 Chief Pullie General FSJ Tech 25 10-28-2011 06:51 AM
Difference between chief and chief "s"? rentalrider General FSJ Discussion 2 04-22-2011 03:33 PM
1979 Baby blue Chief...SAW YOU TODAY! PlasticBoob General FSJ Discussion 0 04-17-2008 08:45 PM
