Old 04-02-2012, 01:28 PM
Iceman0502's Avatar
Iceman0502 Iceman0502 is offline
I want to install Suburban rear gas tank
I know everyone says that that are doing it and I want to as well.
How do you put a suburban rear gas tank into an 82 wagoneer. Is a body lift required? Do you use the suburan sending unit and is that compatible with the stock?
I tried searching but can't find any kind of write up or pictures.
Can anyone help?
Old 04-02-2012, 01:35 PM
kowboy84's Avatar
kowboy84 kowboy84 is offline
Well what I did was cut the fill neck off a 25 gal blazer tank no fuel pump, re weld a 1 inch tube on the side (patched the hole of the fill neck I cut off), at the top, about the middle of the tank, made a skid plate out of 1/4 inch steel 29x29x 6 inches high, I got the tank from craigslist,it was a new one with sending unit,100.00 I got 2 sets of straps off ebay for 38.00. fab cross members out of 3 inch channel and 2 inch angle . I use straps to hold it to the skid plate bolt skid plate to cross member, and off you go, I know you want photos, there in the works.There is lots of room with a 25gal tank and you don't have to cut out your cross member
I did a shackle flip and mounted the springs under the frame, so I have lots of room, but it does not hang down more then stock tank did.
My tank is the last thing to go in, and I am all most there, I will post pictures when I do.
1978 Jeep Wagoneer is my DD, The only way you can stop me ,is buy it.AMC 360, AMC400, Dana300 Twin stick, lockers front and rear.
http://s326.photobucket.com/albums/k...oneer%20Build/
Old 04-02-2012, 01:42 PM
kowboy84's Avatar
I forgot , I used the return on the sending unit. good luck
Old 04-02-2012, 03:33 PM
mdcptman's Avatar
mdcptman mdcptman is offline
Jeep Therapist
Here is a write-up.
http://www.ifsja.org/forums/vb/showt...=suburban+tank
88 Grand Wagoneer
360/727/NP208/dana 3.31s
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
Quote From Friend's Mom:
Trail Blazer Aux tank which way does it install? badaboom General FSJ Discussion 6 07-24-2016 02:16 PM
Calling Suburban tank swappers 76FSChief General FSJ Tech 7 05-22-2011 09:56 AM
FUEL TANK FOR J10 THAT FITS IN FRONT OF REAR AXLE msh227 General FSJ Tech 8 09-21-2009 01:17 AM
BJ's Gas Tank install (MTS Tank) fill hose? pablo_max General FSJ Tech 1 06-11-2009 06:43 AM
Rear brake hardline.....need to remove fuel tank? Nick1224 General FSJ Tech 6 03-22-2008 09:41 PM
