  #41
Old 04-28-2019, 05:23 PM
Originally Posted by babywag
So I cannot find my adjustable pushrod...
Doing the math 18 tpi is .056 @ 1 full rotation?
Which means to obtain .020-.030 = ~1/2turn(.028) after zero lash?
Correct
Old 04-29-2019, 06:23 AM
Yes, your math is correct.
LS1 rocker puts the pushrod seat .040" lower than the AMC rocker from my '90. The AMC rocker ratio measured 1.605, LS rocker 1.715. That's just straight measuring the rocker, not the actual valve lift vs lobe lift measured with a test spring (my engine is still in pieces).
I'm going with the summit K8600 camshaft kit which as .080 smaller base circle on exhaust, .050 on the intake. So I may be able to reuse the factory pushrods on the exhaust and compress the lifter .015 more on the intake.
But the heads, deck were touched, different brand lifters, who knows how the head gasket thickness matches the oem, so I'll find out when I assemble.
Old 07-14-2019, 06:31 AM
JeepsAndGuns's Avatar
Curious if anything came of this, or has the project been shelved?
Old 07-15-2019, 11:54 AM
My engine is together with the factory rockers and pushrods, just changed the oil after break-in. I'll get to swapping in the LS rockers eventually.
Old 07-24-2019, 07:57 PM
I have a ton of stuff higher on my list but I will get to it eventually.
Old 10-13-2019, 04:43 PM
Any update?
Old 10-15-2019, 10:01 AM
Originally Posted by yossarian19
Any update?
Nope...still pretty low on my list.
Old 10-15-2019, 11:25 AM
Chevelleguy's Avatar
Chevelleguy Chevelleguy is offline
I am beginning the engine rebuild process and am going to dive into this too. Ordered a set of Procomp stainless, adjustable LS rockers in a 1.8 ratio to try. The adjustable pushrod seat should fix any minor pushrod issues. I will let you know how it looks after I get the heads back from the machine shop. I got them cheaper than this, but these are the same ones.
https://www.summitracing.com/parts/s...1118?rrec=true
David "If all else fails, read the instructions."
83 Wag Lt,BJ's 6"lift,360/727/Pinned229,D44/trac-lok,AMC20/lock-right,35/12.50 Baja MTZ,Pro-Jection EFI.
10$ NP229 fix http://www.ifsja.org/forums/vb/showthread.php?t=2520
Old 10-16-2019, 09:49 AM
1.8,wow you want good valve springs they are gonna open and close fast.
Old 10-17-2019, 07:01 AM
I got a complete Comp 268H cam kit. 1.8 will put the valve lift at .513, which is only another .057". I got these for less than it would have cost me to replace them with factory rockers so if they work out it's a win. If they don't work I can probably sell them to someone at work. We have a lot of LS guys here.
Old 10-24-2019, 10:14 AM
Well preliminary fitment looks good. Just bolted them on a head, no cam. The roller tip is in the very center of the valve stem and the spacing is correct. Won't know until I get the motor assembled if I will need custom push rods or if shimming of the pedestal will be necessary.
Old 10-24-2019, 11:01 AM
Old 05-17-2020, 06:21 AM
LS Rockers on bridge heads
Found a couple pictures of LS rockers on a 401 I built for a customer. I have a 360 going on the dyno, should be this week, using LS rockers after the break in with factory bridge 1.6 rockers.
I may make a pull with the bridge to compare with the 1.7 LS
http://theamcforum.com/forum/topic10...88.html#927388
Old 05-17-2020, 06:24 AM
Yes please do. I would love to see a actual dyno run with stock rockers and these rockers on the same engine. Would be very interested in seeing where and how much difference they make.
Old 05-17-2020, 09:52 AM
The engine is a 360 with 10:1 CR, street ported heads around 260 CFM at the lift of the cam with the 1.7's. Port matched Air gap intake, hydraulic flat tappet Bullet custom grind, 214/226 @ .050, 114/110 LSA/ICL, .544/.577 lift with 1.7's.
Jeep Headman headers 1 3/4" x 2.5" collector headers.
Engine is going in a CJ
Old 05-18-2020, 10:41 AM
Yeah, please do a back to back test on the dyno if you could. I hoped to do that but am getting grief here at work putting my AMC on the dyno, as we don't have the AMC adapters for the dyno.
If I recall correctly, the GM pedestal stands don't put the pivot in a good height for the pattern. I had to make my own stands. At least I think that's why I made my own stands.
Old 05-18-2020, 11:22 AM
Test here for uploading pics:
https://thumbnails-photos.amazon.com...A23O6GJEQP2OWG
Old 04-21-2021, 12:13 PM
Here I am still attempting to find a place to host images for forums. Lets try flickr...
Old 05-02-2021, 07:18 AM
Are those custom made supports/stands, or just re machined original ones?
Let us know all the details when you get it going.
Old 05-03-2021, 11:45 AM
Yes I made new stands as the LS stand shaft height is too high. .200" removed from the LS shaft height; unfortunately there's not enough there on the LS stand to take that much off. I used mild steel bar from McMaster.
This is close to the AMC shaft height. Pushrod seat on these LS1 rockers is .040 lower than the AMC seat. My cam (Summit 8600) has about .040 more lobe lift on the intake and .055 on the exhaust, so the pushrods are actually damn near exactly where they'd be in the lifter with the factory cam and rockers. Note, the pushrods were fine with the factory rockers too; the lifters supplied with the summit cam have plenty of adjustment.
roller rockers o stamped? yossarian19 General FSJ Tech 3 05-23-2017 02:29 PM
AMC 360 Heads with Comp Cams Magnum Rockers Road Hammer Street & Performance 4 10-08-2015 02:19 PM
For those of you with roller rockers...have a question 78 Arizona Chief General FSJ Tech 26 12-11-2007 10:51 AM
Scorpion roller rockers on 401 baybilly General FSJ Tech 10 03-14-2007 07:26 AM
Who has experience with AMC roller rockers? TexasJ10 General FSJ Tech 7 08-16-2004 07:14 AM
