Pics of what I'm looking at. When pushing on the button to open the rear drivers door, the rod skips above the plate, and therefore doesn't spring back. Only does so once the inside handle is used.
I disassembled the whole thing and it all looks fine enough. But I *think* what's happening is that the downward movement of the door caused by this broken hinge is what's causing the rod to skip off the plate.
But I cannot tell what's happening here. I imagine there should be a hinge pin going through but in the close ups it looks like a solid piece. Can't even find definition that there is/was a pin here. New hinge needed? Is there a pin that should run through there that's just perfectly seared off?
