Old 11-09-2010, 03:07 PM
Eugene 1's Avatar
Eugene 1 Eugene 1 is offline
1979 Cherokee 360 T-18 with hydraulic set up
1979 cherokee 360 T-18 Hydraulic Clutch set up
I was doing some searches on hydraulic clutches and i really did not see anyone with a completed set up on a T-18?
I was wondering what junkyard parts you Hydraulic guys used to make it work if at all or maybe i just missed it on T18s.
I skimmed through several different threads using different master cyl. slave cyl Ax-15,Cjs,tjs,GM.
im trying to find out what would work on a budget in a FSJ with the stock trans thanks Guys !
JEEP
2005 Ram 1500 HemI
Old 11-09-2010, 03:11 PM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
Just get one from a '60s rig if you want oem hydraulics. It uses a simple external slave. Personally, I'm not a fan of things that leak down and leave you inop. If I was having trouble with frame flex I'd switch to a cable operated system or box the frame before I'd go with something I've mostly had trouble with in the past. My F350 is doing well, but everything else I've had with a juice clutch was less than reliable in every day street use.
Old 11-09-2010, 03:18 PM
Eugene 1's Avatar
oh ok thats seems simple enough. I will tell him (my buddy) is there a certain year to look for ? j truck or wagoneer? and would he would just need the line and Mc and the slave cyl. correct ? Thanks E!
JEEP
2005 Ram 1500 HemI
Old 11-09-2010, 03:32 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
Novak sells a kit, as does BJs (repackaged Novak kit from the pics). Most of the parts are CJ parts IIRC.
Personally...I hate mechanical clutches...everything has gone hydro for a reason. No offense Elliott. Linkage is simple, but hydraulics are not rocket science either. Only thing I've ever had cause problems in hydro setups is poor maintenance. It's really no different than a brake system.
If you do go with a hydro setup DO NOT run an internal slave. External all the way.
aa
Old 11-09-2010, 03:35 PM
mweath1's Avatar
mweath1 mweath1 is offline
ttt
Old 11-09-2010, 03:42 PM
Eugene 1's Avatar
were thinking of hydraulic just because of the worn linkages etc..the parts store seem to stock most of this stuff
JEEP
2005 Ram 1500 HemI
Old 11-10-2010, 09:52 AM
Elliott's Avatar
Cowboy Up
I think it's 4wdHardware that has all the linkage bits/bushings (that are cheap) for the CJ and most of that 'cept the zbar interchanges.
Old 11-10-2010, 10:03 AM
Elliott's Avatar
Cowboy Up
aa
Yep, but some are very poorly designed, a pita to bleed and if you lost fluid or got the slightest air in your system you are just down where linkage can always be fabbed up to get you out. The internal slaves can work great, but when they don't you've got a real project on your hands. I've had the worst of luck and the best of luck with hydraulics, with manual I've never had a problem... but then I actually prefer solid lifters and multiple carbs too.
Old 11-10-2010, 10:05 AM
Cecil14's Avatar
LOL. Oh I agree...there are bad setups (my setup has no bleeder...good times). Even then though I will take the hydro setup vs. linkage. Course...I prefer EFI over carbs everyday.
aa
Old 11-10-2010, 12:08 PM
Mikel's Avatar
Mikel Mikel is offline
I used the brake master cylinder from my '63 J300 as the clutch master cylinder. It's much more common than the actual part and very cheap. Works great with my NV4500 setup.
1969 M715 6x6
1963 J300 Swivel frame
Old 11-10-2010, 12:24 PM
I don't recommend robbing CJ parts. My 82 CJ8 at 80,000 miles was on it's 3rd slave cyl. Stock Girling(lucas) parts are junk.
Old 11-10-2010, 01:25 PM
Elliott's Avatar
Cowboy Up
That's what I had fun with on the TRs I had. On the '66 I got my cab off of... it was a late model J20 chassis under it and the T18 must have had a slave because I remember pulling the clutch MC off the firewall and it had a vertical bolt pattern... which I think was Dodge.
Old 11-10-2010, 02:49 PM
Gambler68's Avatar
Rabble Rouser
I had a 65 J300 come here as a parts truck for my Gladiator build..it had a chevy 304, unknown 3spd and a d20. Had a hydro-clutch setup that I yanked and stuffed away somewhere. Ran off a brake MC like Mikel said..looked very simple (which is good considering the quality of the swap.. ) just a actuator bolted to the engine that went down to the arm on the bellhousing and a spring.
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 11-13-2010, 02:28 PM
Eugene 1's Avatar
hmm do you have pics of that? and would it work the same on the T-18
JEEP
2005 Ram 1500 HemI
Dutch Deluxe (1979 Cherokee build) Pullie General FSJ Discussion 24 01-25-2011 10:37 AM
Cherokee: 1979 vs 1983 MMinMN General FSJ Discussion 26 12-04-2009 05:43 PM
J20 360 in to a cherokee?? nitrooxide General FSJ Tech 6 06-08-2009 02:56 PM
1979 Cherokee Chief WT - Dusty Tad Cherokees 0 04-15-2009 07:30 PM
