Old 09-09-2001, 07:28 AM
243 243 is offline
Oil pressure and water temperature gauges?
David
76 NT Cherokee
83 CJ7
05 Frontier CC 4x2
Old 09-09-2001, 07:43 AM
Kris's Avatar
Kris Kris is offline
I put in a mechanical oil pressure gauge and just tee'd off the existing port for the electrical one and kept my electric one as well, that way the one in the cluster still works and I have the mechanical under the dash.
For the h2o, that may be difficult if you want to keep the original one working. If you dont then the sender is on the front of the intake manifold on the drivers side. Just replace the sender and route the wire.
kris.
89 Waggy
AX-15 swap info threads...
http://www.ifsja.org/forums/vb/showthread.php?t=83102
http://www.ifsja.org/forums/vb/showthread.php?t=97262
http://www.ifsja.org/forums/vb/showthread.php?t=104163
Theres more but that should get you started
Originally Posted by JeepinPete
-If it wasn't for bad luck, you wouldn't have any luck at all-
