Old 04-04-2011, 09:10 AM
duncanstives's Avatar
duncanstives duncanstives is offline
Theres a huge, terrifying snake on my engine!
Oh wait... It the wiring harrness...
So yeah... Like I said: A huge terrifying snake.
As you might imagine I am not looking forward to ohming out every pin of a 72 or so pin wiring harrness for my EFI 351... Surely there is an easier way? Like a wiring diagram?
Hopefully a way that DOESN'T involve paying painless a boatload of money for a harrness set up....
Also... Question number 2: The engine came with a set of shorty headers that DON'T feature the huge quanity of, presumably, emission related tubing sticking off like some lab expirment gone wrong like the stock ones do... I like this so I would like to switch to them (Mostly because some of that tubing is in dubious shape on the stock ones). Problem is I am guessing this will make the all seeing computer grumpy and I would like to avoid this... Any idea what this tubing is and how I might decieve the computer with regards to its absence?
88 Waggy
Resting in peace... Um... In piece... Er... IN PIECES
Current Status: Under construction. Phase 2.
86 Pathfinder Conversions "K-Van"
Current Status: Broke
Volkswagen rail buggy
Current status: Broke
95 Jeep ZJ V8
Current status: DDing
Old 04-04-2011, 10:10 AM
Lots of info here it has been a while since I read it, but I do seem to remember there being wiring diagrams or links to the same.
http://www.pirate4x4.com/forum/showt...highlight=totw
Old 04-04-2011, 10:34 AM
Thanks... I have started reading that once or twice. My harrness seems a bit different though than what they are showing there as well as well as other places I have seen ... It has a huge round connector with male pins inside it that I assume went to the firewall of the truck it came out of. From there I assume we have ignition, (start, run, acc, etc), check engine light, fuel pump (maybe... The wires are all small gauge so maybe not), ac switch and who knows what else.
88 Waggy
95 Jeep ZJ V8
Old 04-04-2011, 04:40 PM
csuengr's Avatar
csuengr csuengr is offline
On SBF Fords of that vintage, the air injection tubes went into the back of the cylinder heads. If not, then into the exhaust manifolds. I don't know if the ECM checks for functioning of the air system. I know it looks for correct EGR operation. There is a group of vacuum switches by the ignition coil that control the air system. Hopefully you will just be removing the air pump and its associated hoses.
If at first you don't succeed, use a bigger hammer.
Old 04-04-2011, 05:52 PM
Your using a truck harness? It would be like ford to use something completely different in the trucks. I love Fords been running them all my life but sometimes there engineers mae me want to pull my hair out
Old 04-04-2011, 06:29 PM
Thumbs down
So I can do away with the lab experiment headers without issue... This is good news. I assume there is some little block off plates I put over the spot where this stuff attached to the heads? Also since most engines I have seen dont have them I guess they are not extremely important to performance or longevity of the engine?
Also if the egr valve is what I am thinking (little set of tiny multicolored vacuum hoses?) I will be trying to do whatever is easiest: Fix that system (dispite their festive appearance the multicolored plastic vacuum hoses don't seem to be the best choice... They have become brittle and snapped), or bypass that system.
Finally: the other after market headers (drivers I think?) has a 5th passage... Looks like it should go to a cylinder but it ends in a threaded fitting... I presume I did not get a set of headers designed for the elusive 9 cylinder engine so now I am left wondering what it's for.
88 Waggy
95 Jeep ZJ V8
Old 04-04-2011, 06:35 PM
Yes... The engine and harness came from a truck. I will get a picture of the connector tomorrow if it has quit raining/hailing/having tornados. Until then: it's round and about 4in in diameter with LOTS of fairly light gauge wires going to it.... The connector for the ecu (and ecu itself) looks just like described elsewhere.
88 Waggy
95 Jeep ZJ V8
Old 04-05-2011, 08:04 AM
csuengr's Avatar
The EGR valve is the thing on the passenger side of the intake after the throttle body. Should have a white top with an electrical connector and a tube that runs down to the lower intake. The connector is for the position sensor. The valve itself is controlled by one of the vacuum switches by the ignition coil.
Old 04-05-2011, 08:06 AM
csuengr's Avatar
Forgot, the extra threaded hole is still a mystery to me. I suspect that at some point Ford ran air injection into the manifolds. I have never seen this unless it was on the carbed versions of the engines. Just plug the holes.
Old 04-05-2011, 08:29 AM
Thanks... I will try to find a plug of some sort.
With regards the wiring: The big round connector is sometimes refered to as a "showerhead" connector... Still no luck finding a pin out though
88 Waggy
95 Jeep ZJ V8
rear engine buggy JeepsAndGuns Off-Road FSJ Tech 14 08-30-2008 09:18 AM
V8 Engine Mounts TINMAN93 General FSJ Tech 7 09-16-2006 09:06 PM
Mikes Engine Swap-o-rama will e Events 32 01-08-2006 12:19 AM
Help please Dan G General FSJ Tech 36 09-02-2002 08:47 AM
Is my engine toast? Chero77 General FSJ Tech 8 12-04-2001 11:05 AM
