windscreen chrome strip mounting
  • Tzummie
    • Aug 19, 2006
    • 238
    anyone tips & tricks on mounting the strip (on the rubber) around the front windscreen?
    thnx in advance!
    T.
    1982 Wagoneer ltd.
  • addicted
    Big Meanie
    • Dec 11, 2004
    • 4876
    The sides and bottom are pretty easy to mount it's the top piece that needs a second set of hands. A little dish soap and water in a spray bottle will help to lube the rubber so the metal pieces slide into place easier.
    Originally posted by Ristow
    i bet it was Simon....
    • Tzummie
      • Aug 19, 2006
      • 238
      thnx! Any problem with finding the holes where the screws should go?
      1982 Wagoneer ltd.
      • addicted
        Big Meanie
        • Dec 11, 2004
        • 4876
        Not really. Once you get the trim lined up where it will sit the holes pretty much line up. If I remember correctly the screws are self tapping so if it doesn't line up perfectly you might not even know.
        • Tzummie
          • Aug 19, 2006
          • 238
          ok, cool. tnx. Guess soaking the rubber with soap is the trick..
          1982 Wagoneer ltd.
          • Tripwire
            • Jul 30, 2000
            • 4656
            two extra sets of hands help alot - it took us all day to do mine with a new seal
            Abort? Retry? Ignore? >
            • Tzummie
              • Aug 19, 2006
              • 238
              yep. upper strip took me half a day; "secret" is to make sure the strip form fits the weatherstrip as good as possible. The lower ones are the ugly ones; Due to the somewhat larger size of the underside of the windscreen rubber, also the strips don't fit too well.
              Finding the original screw holes is nearly impossible, and the original screws are NOT self-tapping (in fact, they're the most blunt screws I've ever come across..).
              So need to think of a solution for that. (when trying to "find" the orginal hole, there's so much scratching on the paint going on, that I'm afraid new rust spots will come up there..).
              Swapping the front wind screen + re-installing the strips is a REAL challenge and by far my least favorite..
              1982 Wagoneer ltd.
              • tgreese
                • May 29, 2003
                • 11682
                I recall it was a struggle. I used silicone spray to help slide on the pieces. I was able to do it with no help.
                If I had know it was going to be a struggle, I would have recorded my steps. All I recall is there is was specific order in which the pieces must go on. Also, by looking at the parts, it's surprising that they would stay in place - but once installed, they are all held down tightly.
                • Tzummie
                  • Aug 19, 2006
                  • 238
                  yes, it's indeed surprising the installed strips hold real tight, even without the screws. Going to mark the screw holes with marked tape, so I know where to screw (somewhere)..
                  1982 Wagoneer ltd.
                  • #10
                    Ice pck can help line up and locate your holes as well.
                    Art
                    ASE Master Collision Tech
