Old 12-16-2016, 03:00 PM
asudchiman's Avatar
asudchiman asudchiman is offline
Heating a Garage?
This is my first winter where I have had any desire to be out working in the garage during winter... (correct, it is the first winter with the Jeep).
What do you use to warm up your garage? Cost is a big factor and space too. I have a two car garage.
Thanks in advance for the ideas.
Current Jeep Fleet:
1993 Wrangler Sahara (YJ) Stock, 52k
1991 Grand Wagoneer - [Black] 4" Lift, 32's, 92k
1991 Grand Wagoneer - [Hunter Green] Stock, 60k
1991 Grand Wagoneer - [Hunter Green] Restored (for sale)
Four Wheel Trends
Old 12-16-2016, 03:52 PM
old house furnace off ebay,a high efficiency with the pvc exhaust. should be able to find one for 100-200$
Old 12-16-2016, 05:23 PM
My current single car garage is essentially a plumb full bike shop that has no room for a heater so yeah it's chilly out there. In the past I've always had 2 car or larger shops and always had wood stoves. For that size I like barrel stoves. Gets plenty warm. A small cast iron wood box stove is enough to make it reasonably comfortable to work in. Box stoves aren't expensive and suspect in the Carolinas firewood is reasonably inexpensive and easy to come by. Do check with your local county regs about wood stoves. Some places have strict air pollution regs and wood smoke may not be acceptable? Wood is likely to be cheaper than propane, oil or electric. Always has been where I've lived anyway.
Old 12-16-2016, 05:58 PM
77Deepj20 77Deepj20 is offline
I have a 55gallon barrel wood stove setup in my garage. Works pretty well at heating the entire place, 30x36 9' ceiling. A heavier gauge steel drum or old tank would work even better. Kit cost like 40bux plus a barrel.
1977 j20. Dana 60's, 4:10's Chrysler 360/np435/NWF blackbox/np203
Hummer military 24 bolt wheels and 37" mt/r's.
Old 12-17-2016, 07:29 AM
mokurt mokurt is offline
Is the garage insulated?
This will make a huge difference!
1967 J2000
1985 CJ7
Old 12-17-2016, 08:25 AM
Fearless's Avatar
Fearless Fearless is offline
I have an old Perfection 500 Kerosene heater I gave 20 bucks for 20 years ago. Fire it when I walk in and its warmed up to "chilly" in 10 minutes, toasty in 20. Cut it back to its lowest setting and I'm good for about 5 hours on a tank in a 25x25 uninsulated freestanding garage.
YMMV
Fearless
'89 Grand Wagoneer slightly Modified
"The only time you have too much fuel is when you are on Fire"
Old 12-17-2016, 11:10 AM
Kaiserjeeps's Avatar
As mentioned insulation is a great place to start. My wife and I rented a man lift and did our ceiling in the shop. It made all the difference as before 20 degrees above outside temps is all I could do. Now I can get it to 65 in there and the high yesterday was 18 degrees. I use a woodstove for the main heat. But I bought a 220 heater from Northern tool. It's a 1 foot square orange heater. It does OK but I have felt more heat come from smaller heaters. I also use in tandem a small "Big Heat" heater. It's 120 AC and makes hotter air than the Northern heater. It's only 8 inches square and makes fantastic heat.
I might aim that one at my work area if it is super cold in there. So when it is super cold, like last night at 15 below zero, I use all three and they work fine.
Remember Propane makes moisture when it burns. So that will increase humidity significantly and parts on shelves will surface rust faster.
Good luck and enjoy the winter projects.
Am I done yet?
Holy Moly, I am done.....
1969 1414X Wag,
71 project J truck 4 sale CHEAP
1970 J truck with the 71
1970 Wagoneer Not Sadie
1983 FJ60 wagon
CJ-5's
Old 12-17-2016, 12:18 PM
Absolutely. And most of the heat goes through the roof, so you need as much insulation overhead as you can manage.
I use electric heat (two hanging heaters), and I only heat the garage when I need to. Initial cost of electric heat will be much lower than gas, but the operating costs will be higher. Electric is also safer than gas or wood.
A ceiling fan also helps to distribute the heat throughout the garage.
Old 12-18-2016, 06:54 AM
When I had my 30' x 34' garage built,the walls were insulated but not the upstairs ceiling.
In the summer time the upstairs was extremly hot even with the two windows open and attic fan on.
I had the ceiling insulated for $400 and that made a big difference.
1967 J2000
1985 CJ7
Old 12-18-2016, 09:13 AM
asudchiman's Avatar
The garage is insulated on all sides except the actual garage doors.
Any ideas for getting a heater up off the floor to keep it away from kids?
Current Jeep Fleet:
Four Wheel Trends
Old 12-18-2016, 09:41 AM
EKWagoneer's Avatar
EKWagoneer EKWagoneer is offline
In my dad's shop he put a heater up near the ceiling with lengths of all- thread rod. Think reverse stilts- anchored from the rafters to the top of the heater. Heater is approx. 1.5 x 1 x 1 feet. Maybe a bit bigger. He plumbed propane and exhaust without much trouble- shop already had a propane line.
Hope this helps.
Ely
1973 Wagoneer- nearly stock, work in progress
1/2 1975 Wagoneer- rolling chassis, D44's 6" lift, 35's, work in progress
1992 Chevy Suburban 1500 Silverado, mostly stock, 396,000 miles and counting
I'm a secondhand vegetarian- cows eat grass, I eat cows.
Have A Nice Day!
Old 01-04-2017, 04:25 PM
jeepman1's Avatar
jeepman1 jeepman1 is offline
No thanks
Before moving down here to hot and steamy Cortez, I spent 12 years in Boone NC my house was at 3450 ft. I'd grab a beer, walk out to the garage, stand there and look at the jeep for about 35 seconds , head back in and hope for spring!
: 98 9er
'83 Honcho j10
'12 Liberty Ltd.. wifes
'19 Chaparral H2o Dlx sport 21
Old 01-04-2017, 05:22 PM
It gets cold in the Carolinas?
-Jonny B.
AMC 401 - Pro-Flo 4 EFI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 01-05-2017, 07:19 AM
SC/397's Avatar
SC/397 SC/397 is offline
I would find a used counterflow furnace out of a Mobile Home for that small of a area. Build a 6-8" tall metal box under it with the opening to the area you want heated. .
I have a 85000 btu oil furnice in my shop set up this way and it will roast you out of there. The heat blows right on the concrete floor and it is great. If I build another shop, I will set it up the same way. I don't run any ductwork in to it, it just pullls air from the inside of the shop.
Old 01-05-2017, 08:08 AM
asudchiman's Avatar
Heavy Metal... just because we don't all use sled dogs to get to work doesn't mean it doesn't get cold here.
We have all 4 seasons. That's why everyone keeps trying to move here.
Here's what they are calling for tomorrow. Good thing about snow around here, it turns into a big neighborhood party. Everything shuts down, kids go out to play and two days later its warm and the snow is gone. Best kind of snow to have.
On the other hand, last weekend I was doing this just 3 hours away at the beach in 50 degree weather:
With this said, I know it's all in good fun and yes, cold is relative! Cheers
Current Jeep Fleet:
Four Wheel Trends
Old 01-05-2017, 10:51 AM
Mex in the city's Avatar
Mex in the city Mex in the city is offline
It does get cold in the carolinas. I have a kerosene heater. It does the trick.
83 Wagoneer. Front: 35 spline D60, Coil spring conversion, E-Locker. Rear: Sterling 10.5, Shackle flip, Detroit. Gear ratio 5.38:1. 39.5 Interco Irok's, HEI, hydroboost, hydroassist, bob job, sliders, roll cage, 12K winch. Runs on propane!!!
87 GW, 3", 4.10, 32" BFG AT, K8600, 2131, 1406, HEI, hydroboost.
71 Datsun 240Z turbo.
Old 01-05-2017, 11:34 AM
SJTD SJTD is offline
I don't see anyone on skis behind that boat.
I've got a radiant heater that fits on a five gallon propane tank that I can't use because my tank doesn't have the internal float valve and I'm too cheap to buy a new tank.
It's nice when the garage in in the 50's.
Sic friatur crustulum
Old 01-08-2017, 12:37 PM
grand_wag_85's Avatar
Murphy's Law Poster Child
For now I use a pair of salamander heaters, one kerosene and the other propane. My garage is an old dilapidated great depression era building so it's full of holes and not one ounce of insulation. With those heaters in that building it's quasi bearable but still cold.
I'm working on getting a new garage built and it will likely be a Morton type steel building. For heat I've got an outdoor boiler so there will be a ceiling mounted blower and if the budget permits heated floor. That's my pipe dream anyways.
'65 J2000
Old 01-10-2017, 04:48 PM
asudchiman's Avatar
jeepman1, my bio photo is from the blue ridge parkway between Boone and Blowing Rock and I went the App State. It took me about 6 years to adjust to temps off the mountain.
Current Jeep Fleet:
Four Wheel Trends
Old 02-02-2017, 02:20 PM
rockrollin's Avatar
rockrollin rockrollin is offline
I use a lpg patio heater in my barn. Even though you can almost feel the outside wind (not insulated), it does keep a 25'x25' area pretty cozy. My garage is insulated, and heated by a Modine heater, it will heat up to a toasty 70 no problem. I reserve the back of my garage for bigger projects.
OI!IIII!IO "I like fun" Eddie Ott
Clawed 90 GW
Slightly off stock
Will the FSJ blow up the garage? Kenall General FSJ Discussion 22 01-19-2017 09:50 PM
Painting garage with exhaust pipe? Woody the Danger Wagon General FSJ Tech 12 04-05-2010 04:23 PM
Exhaust extension for running vehicle in the garage shiner2001 General FSJ Tech 7 04-27-2009 11:27 AM
Media blasting in the garage - ya, I'm crazy gte901m General FSJ Discussion 8 10-14-2008 11:24 AM
garage/ height question ? trickc General FSJ Tech 9 04-16-2001 04:05 AM
