Old 04-07-2014, 05:24 AM
mdcptman's Avatar
mdcptman mdcptman is offline
Jeep Therapist
Why are the GW hood ornaments spring loaded?
Why the spring on hood ornaments? Why arent they mounted solid? I broke mine yesterday, and I found that it is held on by a spring and VERY small piece of weak metal that the spring goes thru. I put out a call on another post for a replacement, but iIm thinking if drilling it and mounting it solid. Why wont this work?
88 Grand Wagoneer
360/727/NP208/dana 3.31s
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
Quote From Friend's Mom:
Old 04-07-2014, 06:49 AM
Hunter Green 91 Hunter Green 91 is offline
Spring loaded to prevent damage to pedestrians you may hit. It also prevents breakage in case something or someone accidentally hits it. Mounting it solid shouldn't be an issue.
1991 Grand Wagoneer
1967 J-100 Panel Delivery Military
Old 04-07-2014, 07:04 AM
men in black's Avatar
So they will bend over and twist a little going though the car wash.
Also the spring hole is used so you can hang it from that big GOLD chain around your neck.
Old 04-07-2014, 08:05 AM
Tripwire's Avatar
Tripwire Tripwire is offline
Abort? Retry? Ignore? >
Old 04-12-2014, 08:15 AM
charlie500's Avatar
charlie500 charlie500 is offline
I used J-bond on mine.
Hood Latch Spring awoodfellow General FSJ Tech 1 05-27-2010 10:03 AM
Hood lock adjustement..... Tatsadasayago General FSJ Tech 0 02-09-2010 02:34 PM
hood release mount when switching to a rhino grill 72wag General FSJ Tech 9 08-11-2004 11:21 PM
pre 73 3" spring lift info miked General FSJ Tech 8 04-07-2001 07:11 AM
