  #41
Old 05-25-2012, 08:43 PM
j20owner's Avatar
j20owner j20owner is offline
Originally Posted by Nick1224
The tranny shifts too slow and smooth for my tastes, but that can be changed.
Did you put in a shift kit?
I've hooked the dash cluster and BCM up from an 02 silverado and now have all functioning dash lights. This also give me the ability to hook up a tow/haul mode button.
None of that is needed for tow/haul.
I'm thinking of hooking up the gm headlight switch to get automatic lights and also wiring up the "driver information" so I an read out mpgs and compass and other useless stuff.
More trouble than it's probably worth!
Spent the last two days ripping out old wiring from behind the dash. Cleared out lots of room.
I might drive it to the Keys this weekend.
Like the build man.
Hey, I just reread the thread and saw you typed something about a 'swap guide'. What's that about? Curious!
Where is my axle?
79 j20/84 GW GM Hybrid
Old 05-26-2012, 08:26 AM
Nick1224's Avatar
Nick1224 Nick1224 is offline
No shift kit yet (budget), that's my plan for changing part of it. But I can also tune it through the PCM.
You can wire tow/haul through the PCM, but the BCM makes the wiring cleaner.
I'm trying to put all my info together to make it easier for future swappers. A good 20-30% of my time is spent part searching.....maybe more.
88 GW...6.0/4l80e/241c swap. Just finishing loose ends. Old MSII TBI wasted spark for sale.
Old 05-26-2012, 09:19 AM
j20owner's Avatar
If you need any help with schematics, let me know.
And I stand corrected, on the 4l80e the tow/haul does go through the bcm. I swear I looked at the tow/haul before and I swear it went straight to the PCM. Now, looking at the schematics, it' doesn't..... Not sure what I was looking at before, but I'll figure it out!
Where is my axle?
Old 05-26-2012, 09:26 AM
Mavawreck Mavawreck is offline
A guide to this swap would be awesome. Also if you don't mind sharing your budget for the project, that would be really helpful too for us dreamers and contemplate'rs
1988 Jeep Grand Wagoneer
http://www.ifsja.org/forums/vb/showthread.php?t=153928
1996 T100 SR5
Old 05-26-2012, 08:09 PM
Nick1224's Avatar
I've been putting prices with my parts lists. The ones I remembered to keep the receipts.
Old 05-28-2012, 05:32 PM
Nick1224's Avatar
Got her out on the highway today. Cruises at a little over 2k doing about 65-70. I hardly ever revved it past 2k driving around in the city.
Decided to make sure the tranny was working and went WOT. Down shifted fine and boy does she sound like a hotrod. 3" hooker maxflow. Scared some girl next to the road.
The beauty of OBD2: It threw a code for high IAT circuit. I openned the hood and looked at the connector, and sure enough the pin was dislodged. Fixed! I also use a bluetooth reader and my Droid to watch as many gauges as I want. The app is called Torque...for free!
Old 05-28-2012, 06:44 PM
j20owner's Avatar
The app is free, the little blue tooth plug usually goes for around $50, right?
Where is my axle?
Old 05-28-2012, 07:20 PM
grand_wag_85's Avatar
Murphy's Law Poster Child
Do you have enough miles on her yet to have any MPG #'s?
'65 J2000
Old 05-28-2012, 08:06 PM
Nick1224's Avatar
Yeah, you need the ELM327/OBD2 bluetooth adapter. I've seen them in the $30 range, but my dad lent me this one!
No mileage numbers. I guess I could go and fill it and see later this week. The thing can live under 2krpms all day. Really don't need to rev it. Did 80 mph and it's just above 2k.
Things left to do.
1. Adapt GM fuel level sender to Jeep unit.
2. Get new bolts for front bumper.
3. Adjust parking brake.
4. Keep checking fluid levels like a crazy person!
Old 05-28-2012, 08:16 PM
j20owner's Avatar
What is your axle gearing and tire size? Just curious.
Where is my axle?
Old 05-28-2012, 08:46 PM
PlasticBoob's Avatar
All Makes Combined
Sounds like my 401! I'm at about 280+hp and 400+ft-lbs though.
Rob
Click for video
[b][size=2]
Old 05-28-2012, 08:55 PM
Nick1224's Avatar
I have the stock 331s (towing package) and OEM sized tires...for now.
I love the 401! Would have gone that route, but I wanted the OD tranny and the OEM aluminum heads was nice. My wife said " are sure this engine is OK, it doesn't sound like it's revving".
Thanks for chiming in guys!
Now, maybe a little midnight run is in order
Old 06-14-2012, 08:52 AM
Nick1224's Avatar
Soooo....drove it to Key West two weekends ago. Mostly speeds between 35-80, avg at about 60. Did 298 miles on 14.6 gallons. Id say that pretty good! Did find out that my new fuel sender doesn't quite reach the bottom of the tank, and I'll have to address that sometime, but not a priority when I can go 300 miles!
Gears are too low, or it's not holding gear for long enough. Good for mileage, but the thing hardly ever goes over 2krpms unless you mash the throttle...then it goes. My wife was stunned when we passed someone at 95 and the Jeep just wanted to keep going. No lack of power or torque.
Knock sensors were rusted out and need to be replaced. There is a TSB about this and requires putting a dam of RTV to keep water out of the rear knock sensor. I put antiseize all over as well to help protect it. Also cleaned out the intake runners that were full of gunk. Seems to run a bit better.
Last weekend we moved to ABQ. Decided to put the Jeep behind the Budget truck. Just wasn't sure about a 2000 mile trip after only 400 miles of trial. Love it here. No I just have to wait 3 months for our house/garage.
My dad got to drive it after the move. He bought it in 88. STill can't get over just turning the key to start it. I think he likes the power too.
Things to do:
Finish dash - long term
Exhaust gaskets - blew the copper RTV, going to try a gasket
Parking brake - wait till house and access to a weler
Old 06-14-2012, 08:57 AM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
20.4mpg is awesome! Especially with a 6.0
BJ's Off-Road
ryan@bjsoffroad.com
Old 06-14-2012, 09:33 AM
Nick1224's Avatar
To be fair, I was just cruising along without much stopping. call that highway mpgs.
So looks like the 727 and 4l80e have almost the same ratios (+OD for the 4l80e). I believe the np241c is 2.7:1. What was the np229?
Old 06-14-2012, 11:57 AM
JeepinPete's Avatar
JeepinPete JeepinPete is offline
2.63 if memory serves me.
20 mpg is better than I ever got out of my 5.3L. But 35" tires probably didn't help matters.
Pete
'55 Willys Wagon, the original FSJ
Sitting on a '77 Cherokee frame, Dodge D60's
Isuzu 6BD1, NV4500, NP241
Old 07-01-2012, 03:38 PM
Nick1224's Avatar
Sooo.....2.5" secondaries did not fit so well. They got "self-clearanced". I think it's fine, just a little dent. My Jeep is at stock ride hieght, with the bump stops extended an inch. Maybe a lift would help things?
Up to 700 miles! Still getting good gas mileage.
Old 07-11-2012, 08:56 PM
Nick1224's Avatar
No problem ABQ emission! 6.0L with a highflow cat.
Old 04-05-2013, 10:20 AM
Nick1224's Avatar
Well, she's got 7500+ miles on her and I love it everyday. Cruising at 80mph is like nothing. Been getting more like 17mpg since I'm doing more city driving. Power is fun to say the least.
Well I'm working at the Veterans Affairs hospital and someone decided they like my stereo and subwoofer, smashed the small rear door window, bent the seat trying to get the subwoofer out, and destroyed the dash. They might have got the guy on video, and it is a federal offense since it was on federal facility (so they say). Poor Jeep
How do I replace that rear window? Is it like the front vent window? replace the track w/ window? Good thing is there is a junkyard here with a GW in it.
So pissed off
Old 04-05-2013, 11:22 AM
Bummer on the theft, the small window is fairly easy to replace.
IIRC the big window needs to come out to allow removal of the little one.
You disconnect the track from the bottom of the big window.
Then it drops down(one side of the glass has a rounded corner?) that allows tilting it and removing it from the track in the door.
The little window has a frame around it that is the rear track for the big window.
Remove the screws in the top door frame, and nuts holding it into lower portion of door.
Tilt it towards the front, and drop down into door, then pull it out/up.
The frame around the small window comes apart after removing a couple screws for glass replacement.
J300 build up thread (motor is here) KaiserMan General FSJ Tech 99 03-21-2021 07:02 PM
1987 GW Build Thread rawdave General FSJ Tech 72 07-24-2012 07:48 AM
WHY NO BUILD THREAD????? CONTINUED!!!!!! BlackrockMotorSports General FSJ Discussion 110 12-03-2009 11:39 PM
Question - WHY NO BUILD THREAD? msh227 General FSJ Discussion 38 12-01-2009 07:36 PM
