  #561
Old 09-21-2022, 05:33 PM
cu4whln's Avatar
cu4whln cu4whln is offline
In Today's News . . .
Thanks Melford1972.
Been busy with family stuff.
I have no complaints..
The wife has been MORE than understanding with my focus on the Jeep this summer!
So a couple of items...
Here are the little clips that the arm rests attach to.
Best to add a small amount of Goop to hold them in place before they get knocked out by accident.
Ask me how I know !
[IMG]http://[/IMG]
ASLO -
It is best to install them BEFORE you put the panels on.
Hmm, I was short some clips, so put the rear panels on figuring I would get some clips later. ( I did btw )
Its really easy install these normally, but NOT after the panels are on.
So how to proceed ... ??
I used the armrest bolt to hold the clip and feed it through the panel hole.
Not easy to manipulate it into position. Might have been easier to remove the panels again...
[IMG]http://[/IMG]
[IMG]http://[/IMG]
An hour later? Got them in.
Dammit this was frustrating.....
Lesson : Put the dam clips on BEFORE the trim panels !!!
1977 "401" 'Da Chief
1979 Chero: "Madness" [Sold]
2001 XJ : Driver - 2016 JK 2 door
Round 2- LT Swap: 'Da Chief:
"Madness" build here:
Old 09-21-2022, 06:10 PM
cu4whln's Avatar
What is this latest delivery??
[IMG]http://[/IMG]
It's the headliner!
The kit from BJs Off Road btw.
I did NOT expect it to come rolled up ??
Step one :
Remove from box, and roll it the opposite way to try and get it flattened out.
[IMG]http://[/IMG]
After some time, laid them flat, letting them settle into a somewhat flat configuration again. ( "Somewhat" )
[IMG]http://[/IMG]
Note there is a front and back piece to deal with.
Here is the larger front piece.
Note, it has the cutouts for the dome lamp and sun visors.
There are a few layers...
Foam board, foam, headliner fabric, and some reinforcements here and there.
[IMG]http://[/IMG]
My buddy came over to help.
Good thing!
Installing this was like putting a wet noodle into a precise location in a 30 mph wind. UGH
Here it goes...
Into the Jeep.
Get it as close to final position first, then try to get the edges parrallel and square. ( Good luck with that! )
[IMG]http://[/IMG]
Instructions were very general.
One of the confusing parts... there is extra material on the edges.
They say not to tuck it up under the headliner as it is installed.
They state this is to help with things not being straight in the Jeeps.
I am still not entirely sure how to finish this yet.
[IMG]http://[/IMG]
After hours of fussing, we got the basics installed.
Now, unlike the "directions", we left the front header piece installed loosely with a few screws.
This enabled it to help hold the front in place while we fought with each side.
We also made up a contraption to hold the rear up while we tried to fit the front. ( Boxes )
Would have been better to have at least 3 people !
[IMG]http://[/IMG]
Then installed the front dome lamp.
Note - It takes more trimming to open up the hole...
And not easy to locate the mounting holes.
[IMG]http://[/IMG]
The basics installed
Note, the extra material is not yet dealt with.
[IMG]http://[/IMG]
I asked they leave out the rear switch cutout - and they did.
In addition, they also left out the rear dome lamp hole as well.
More fun locating that!
Had to relocate the center strip slightly.. ( the metal part mounted on the body)
This is the part that the center trim snaps onto.
This is my old trim, temporarily installed as it's damaged / broken.
Have a somewhat better one, but would love to find a MUCH better one. ANYBODY ??
Again, note the extra material hanging below the edge rail holding the headliner on the sides.
[IMG]http://[/IMG]
Next up? Sun visor mounting
Yep, had to do a lot of trimming to get the plastic trim buckets to sit well.
Be very careful as these things are easy to break!
Get them to lay flat on the sheet metal surface before installing the visors over them.
Oh, and trimming the headliner? One would think it was easy, right?
NOPE. pita. Very tough to cut through the various layers.
[IMG]http://[/IMG]
Pass side installed:
[IMG]http://[/IMG]
"Extra" fun .. had to run the Compass/Temperature rear view mirror wires up over the headliner and not drill through them.
Cut a slot at the forward edge for clearance
Oh, also had to run the radio mic up there too for the Bluetooth.
[IMG]http://[/IMG]
Most everything installed...
STILL have to figure out how to handle that extra material and make it look nice ??
[IMG]http://[/IMG]
Two of us started at 10 am...
Brad left at 3:30 pm.
I finished up around 7 pm. And it's not complete.
Long tiring day.
Old 09-22-2022, 07:07 PM
78 WIDETRAC's Avatar
The headliner and jeep is looking good!
I have a couple of the headliner center pieces one is spoken for. They are for 79 and later, I don't know if it would work for you. It's a solid wide piece of plastic not shiny chrome. I can send you a pic. Let me know if you are interested.
Old 09-22-2022, 10:07 PM
cu4whln's Avatar
Awesome! Sent you a pm...
Old 09-24-2022, 10:26 PM
cu4whln's Avatar
Headliner - "Completed" ??
So, after messing around with the extra material, I came up with a way to tuck it in.
Again, this was not clear in the directions really.
Right or wrong, I ended up "rolling" the extra material to outside of the vehicle, then used a trim stick to wedge it into the channel.
In some areas, it is a VERY tight fit. Be careful!
Is this right or wrong? I surely don't know, but it's the best I can do.
Here is the "roll" and "tuck" into the u-channel mounting gutter for the headliner.
[IMG]http://[/IMG]
[IMG]http://[/IMG]
The "Finished" headliner
[IMG]http://[/IMG]
[IMG]http://[/IMG]
Added the corner trim pieces as well ...
They "fit" sort of well, but not really.
[IMG]http://[/IMG]
The headliner does not fit into the channel all the way forward?
At the front maybe 30" or so, it sits above the u-channel.
I think this is what the extra fabric is supposed to cover/fill?
The headliner is secure, but is maybe 1/2 to 3/4" short on each side.
Thus, you don't get the nice crisp line you see at the back.
Look at the outer edge next to the Sunvisor -
See the line? Thats the extra fabric bridging the "gap" since the headliner is short to reach the rail.
Maybe someday it will settle down into it?
[IMG]http://[/IMG]
So - This $550 headliner kit?
I would rate it an "8.5" out of 10.
Overall, it delivered a decent looking headliner -
I mean, in some respects, I am sure a LOT of work went into this part to make it work.
And it does - mostly. You can see some of the various reinforcements going across. Not the end of the world I guess.
BUT -
The lack of clear directions and no illustrations on how to deal with the extra material? Boo !!
AND -
The fact the fit was off by 1/2" to 3/4" from the B pillar forward.. Dang.
Can't get a sharp edge at the mounting channel.
Now, I didn't expect it to be perfect, but 3/4" is off a fair amount?
So, I call it "done".
BUT - maybe some time in the future, I will try and make some insert material to help make the edge line better at the front?
For now, I have bigger fish to fry!
Like getting the seat brackets made and seats installed.
Old 09-25-2022, 09:41 AM
SJTD SJTD is offline
Disappointing. You seem to be taking it better than I would have but overall it looks good.
But if you're like me it'll fade and you won't notice it anymore. I got a few wrinkles in mine and that's how it is for me.
My corner pieces fit like that. In screwing around with one of the fronts a piece went flying and got lost so I made a form out of wood and formed them out of ABS using a heat gun. They don't look too bad and I figger I could make them better if I want to bother. The piece did turn up so I can glue it if I want. They can be solvent welded or glued with ABS cement.
Sic friatur crustulum
Old 09-25-2022, 09:50 AM
bkilby's Avatar
bkilby bkilby is offline
Too bad about the fit issues but it does look good from my chair..... 2300 miles away. I think my headliner runs a little shy up front too. But then again, mine isn't brand new. That interior sure is looking good.
Old 09-25-2022, 07:26 PM
letank's Avatar
letank letank is offline
Impressive how to, thank you for posting the steps for the headliner install.
Yes the corner pieces fit randomly sometimes, if you do not tuck the OEM headliner right, then there is an extra layer and you break a corner piece!
Michel
85 Gwag, 229 Kmiles. $250 FSJ test lab since 02, that refuses to give up but still leaks.
Old 09-26-2022, 08:39 AM
cu4whln's Avatar
Thanks ...
( Those pesky corner trim pieces! )
Headliner:
I have no choice at this point. I don't think it's bad enough to warrant a complaint.
It is made very clear this is a non-returnable item when you purchase.
Now, as I said, overall it looks good.
My Jeep is a home built, garage tool job done by me and only me.
I am not a professional. I am persistent though!
This is going to be a "driver", not a show vehicle.
It will not be perfect, nor do I want it perfect.
So, it's good enough !
I have shared this "journey" so others who aspire to do their own build can reference this info. Pictures help me a lot!
Old 09-26-2022, 08:41 AM
cu4whln's Avatar
Thanks Brad !
Is it only 2300 miles? Gonna swing by when we drive to Burbank . . .
Our two "Lori's" need to meet !
Old 09-26-2022, 06:50 PM
When you gonna be in Burbank? I might be down here and would love to shake your hand and say hello, too!
00 Baby Cherokee
Old 09-26-2022, 07:51 PM
jeepman42 jeepman42 is offline
Wow! Audio /dash is amazing .Have done dash metal repaint, &'85 wheel repaint but this is over the top. I must be getting old! Correction , I am, just keep acting like I'm not.
'85, '90 GW's, '06 Commander-+ everything else at the house- how did I ever have time for work. LOL
Easy doesn't do it!!
Old 09-26-2022, 08:12 PM
Smile
Best of all this is that persistance pays off (think junk yard dog,I do)
Many of us SJers & other Jeepers have gone through this in years x1000s of hours to have our rigs be what we want. IT'S a Jeep Thing, You Wouldn't Understand! (Unless you do) Thanks to you guys & girls for keeping me inspired!
Old 09-27-2022, 12:24 PM
Me too.
Old 09-27-2022, 01:53 PM
cu4whln's Avatar
SJTD " Me too.
__________________________________________________ ___________
Well, not entirely sure.. but maybe next summer.
Assuming all is complete and worked out.
I would love to meet and catch up with everybody..
Brad _ you will be hosting !! lol
Old 09-28-2022, 07:20 AM
bkilby's Avatar
Bring it on!
Old 10-01-2022, 08:59 PM
cu4whln's Avatar
Next Up . . .
Thanks Brad !!
You are so cool !!
Been a slow week. Haven't felt well..
STESSFUL WEEK : My family was heavily affected by IAN. Sigh.
Heading down next week to asses the situation.
BUT -
My dad is safe, and our houses made it through, mostly.
We are between Napels and Ft Myers, so you know it's SHOW down there.
Old 10-01-2022, 09:39 PM
cu4whln's Avatar
So, the seat project . . .
Finally got together with my buddy who has a welder, and knows how to use it.
Tackled the Pass seat first.
How did I decide where/how high to mount the new seat?
Installed the original seat and measured the full travel front and rear.
Then measured the height of the seat at the front and rear of the cushion at the mid track position.
Then, mocked up the new seat after removing it's original mounting brackets.
Figured out how to use 3 of the 4 original holes with some fabricated brackets.
[IMG]http://[/IMG]
Took some square tubing, and cut the required angle to set the new seat at the proper angle for comfort and position.
[IMG]http://[/IMG]
Clamp into position:
[IMG]http://[/IMG]
Note - the new seats have twice the front/rear travel adjustment compared to the original seats.
Pass seat is a manual track btw.
Then tack weld the new mounts to the seat track.
[IMG]http://[/IMG]
Front mounts:
[IMG]http://[/IMG]
Each mount is different due to the holes and floors being so random in the original design.
However, I want to use the original bolt mounts since they are reinforced strong mounting points.
Rear mounts:
[IMG]http://[/IMG]
Then make and weld some mounting tabs to the angled stand off mounts.
[IMG]http://[/IMG]
Since the front mounts are in the same plane, just made a strap across to capture both sides.
This keeps the track sides connected and in the same position.
All ready for a trail fitting . . .
[IMG]http://[/IMG]
Step one.. Just lay seat into the Jeep
[IMG]http://[/IMG]
Noted the seat doesn't sit "flat"
Got the calibrated hammers out and "fixed" the floor to make it fit the seat mounts.
( Yea, I beat the hell out of a couple of spots...)
You don't realize the floor is not originally flat til you try and mount the nice straight seat you just fabricated on the bench.
Is this only my Jeep, or do all SJs have so many contours in the floor?
I made it work.
Then took the paint pen and marked roughly where the seat goes.
Also verified that the new mounting straps lined up with the holes.
[IMG]http://[/IMG]
[IMG]http://[/IMG]
Now, finally, I can drill the holes and trial bolt the seat in.
BUT - that will have to wait til another day... Family time now!
Old 10-03-2022, 07:25 AM
cu4whln's Avatar
No projects updates...
Jeep is on "hold" for a bit.
Life is happening.
I will be off line for a couple of weeks.
Have to head down to the Florida home to repair our house. ( Ft Myer area)
Also - help other family with their houses.
Loading fuel, food, supplies and tools in prep to go.
It's a mess down there, but our property can be repaired.
All family is safe, many can't say that.
Old 10-03-2022, 07:48 AM
Be safe down there. I'm glad your family is safe, and your property is repairable.
What's a SUPER Chief - OLD TOPIC MESS UP...REPLY HERE! testuser General FSJ Tech 10 12-06-2015 11:10 AM
Difference between chief and chief "s"? rentalrider General FSJ Discussion 2 04-22-2011 03:33 PM
Cherokee vs. Cherokee Chief ??? Jeff in north Texas General FSJ Discussion 6 07-19-2008 09:54 AM
1977 Cherokee Chief - Lea Adams Dome Cherokees 0 08-21-2005 11:45 AM
