I did the 5 volt gauge conversion to an extra dash cluster I had laying around. I followed the write up on this thread: http://www.ifsja.org/forums/vb/showt...=120103&page=4
I hooked some jumper wires to a battery and used a fuel sender as a variable resistor. Both the oil and fuel gauges worked but the temperature gauge will peg hot even without anything hooked to the gauge.
I took it apart, looked for problems, found none. It has 9 ohms resistance to ground w/o a sending unit attached. The other 2 had about 30 Ohms w/o a sender.
I did remove the noise suppression jumper from the circuit board.
Do I have a shorted temp gauge or is there something else going on here?
Thanks.
Thanks.
