when you installed your HEI and bypassed your ignition module, what did you do with the to plugs that ran into your ignition module. do i just let them hang out? can i cut them back? get at me
HEI users
I got danglers tooJennifer: 89 GW 360/727/D44 2"lift 31" BF KM2
Harriett: 97 chevy 2500 ext cab P/U 6.5 TD
Lorraine: 73 Datsun 240z
07 Colorado
http://s1196.photobucket.com/albums/aa416/hookedup50/
mine was
Circumcised
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
LOL
Originally posted by Kenallcaptain wears his cap to dinner.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
nipped them.82 Cherokee WT ? SFwith Alcan/agr box/Borgeson shaft/ 401/performer/Holley TA/HEI/BeCool/727/ALTAS(2.0/2.72/5.44)/D60 Snofighter(Yukon Zip,hubs,stubs,4.56)/14 Bolt (FF,BF shave,Discs, ARB,Artec Truss)/MTR 37/Corbeau Moab Seats /Hella/tuffy console/sliders/custombumpers&roll bar/WARN 8000/steering brace/CO2 Tank/dual batts/custom TCskid plate
1981 WT Cherokee Chief /360/TF727/208/ Holley 600CFM/ Performer Intake/ Edelbrock headers/ Skip White HEI, switched dizzy gear. Patriot Side Pipes.
I cut and heat-shrinked the tips of the wires on mine, just to make sure no bare wires touched each other.'89 GW; 4" Susp Lift on 32" Wild Country MTX; 360, HEI, Edelbrock Intake, Melling MTA-1 Cam, Summit 600 carb, 3.73 Gears
'70 Wagoneer; stock Buick Dauntless 350, TH400; 3.73 stock gears
'83 Wagoneer Limited; stock 360, 727, 3.31 gears.
I left mine and just zip tied them out of the way. Figured I should keep them hanging around for a little while incase something goes wrong and I have to quick put all the old stuff back in.1983 Jeep Cherokee Laredo - The "SwackMobile"
2005 Jeep Grand Cherokee Limited - The "Buford Bus"
2011 Dodge Ram Outdoorsman (the player to be named later)
cut'em all jackPlaces to Wheel in the Southeast
Originally posted by Topgun2moI would think boxing would limit the amount the frame could flex over obstacles which I think IMO would be a bad thing. I would think you would want all the articulation possible.Originally posted by johnny019I'm not saying lockers don't improve the performance of your rig, just that they're overrated.
dangle
Mine dingle dangle dingle as I go riding merrily along!91 Grand Wagoneer "Final Edition"
DeWooded
6 inch Hellcreek lift.
Rhino Grill
Holley 600cfm
