1988 GW power windows don't work. Took the door pannel off and pealed the plastic back. The window is on the track and you can push it up and down, just don't push it all the way down b/c it won't come back up. The motor is working fine and the gear is turning. The plastic thing that pushes and pulls the window along the track has broken. Therefore, when the window is rolled down the gear keeps turning and the plastic track keeps going until it runs out of gear. You can push it back to the gear and it will grab and push the window back up. It is broken near the window and will not pull it down.
Does anyone know where to get the plastic track? What else do you take off to get to it and put a new track on the metal runner and connect it back to the window?
Jason
1988 Grand Waggoner & 1990 YJ
Jason
