I was lookin at the Ole Toms diagram and it states the 10 ga. tan power wire should be hot, but mine is not in key-on. The rear window opening function is intermittent, it will only open on a severly bumpy road, indicating either a loose, broken connection or a failing wire or bad switch?
Any ideas folks? Appreciation in advance, you all have saved my bacon on numerous occassions.
- I did check the pre-harness underneath, no voltage key-on
- Continuity test at the repaired tailgate area, 100% fine
- Connection on safety switch is strong, not loose
