Was setting up carb yesterday and noticed when I pull vac on the vacuum pulloff, it will very slowly release after a few seconds - do our pulloffs (as fitted to a MC2150) have built in bleed or is my vacuum pulloff defective? Thanks
Carburetor Vacuum Pulloff Question
Originally posted by warmblood58Was setting up carb yesterday and noticed when I pull vac on the vacuum pulloff, it will very slowly release after a few seconds - do our pulloffs (as fitted to a MC2150) have built in bleed or is my vacuum pulloff defective? ThanksTim Reese
Yes, some(NOT all) choke pulloffs have a bleed hole(s).
You should be able to spot the hole(s) if you look.
If it pulls the choke flap open slightly when engine starts it's working.
Cheap part if you desire to replace, but keep in mind many new aftermarket parts are crap these days right out of the box.Tony
Originally posted by babywagYes, some(NOT all) choke pulloffs have a bleed hole(s).
Cheap part if you desire to replace, but keep in mind many new aftermarket parts are crap these days right out of the box.James
'88 GW Sterling Silver Metallic
Previously 1987 GW
