Old 03-30-2007, 10:09 PM
Tigger4X's Avatar
Tigger4X Tigger4X is offline
Question How do you install new outer shafts on a 1 Ton GM Dana 60???
I have already tried searching the techinical archives but found nothing about replacing outer shafts.
What I have is a 1 Ton GM Dana 60 out of a military CUCV. One of the hubs croaked so I decided why not upgrade the outer shafts to 35 spline along with getting new Warn premium hubs as well.
Does anybody have a technical/mechanic's manual for this task OR know of a source
Originally Posted by will e
Old 03-30-2007, 10:25 PM
bigjeepthing bigjeepthing is offline
The bigger shafts use the same parts as the stock shafts except the hubs and the c clip on the end.
ITS A FULLSIZE JEEP THING AND NO ONE UNDERSTANDS
Old 03-30-2007, 10:28 PM
mdill's Avatar
mdill mdill is offline
Gone. Not Forgotten.
I would search over at pirate, those guys are into the big Dana 60 stuff more than the guys here.
Mike D.
Old 03-30-2007, 11:05 PM
Crazy_Jeepman's Avatar
Sloppy Shifter
No different than pulling the D44 apart. Calipers come off, hubs, wheel bearings, Hub/rotor, then spindle, pull axle out and press Axle joint out and put new one in along with new outer axle.
Old 03-31-2007, 01:30 AM
Tigger4X's Avatar
Never pulled an axle apart before I guess one would be alot like another though
Thanks for the info CRAZY_JEEPMAN
BTW ... do I, or should I, get a shop to press the old axle joints out and new ones back in
Old 03-31-2007, 04:06 AM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
They aren't that hard to do at home with a combination of tools, you shouldn't need a shop to do it if you have some basic tools. Looking at what you plans are for your build I'd recommend that you just buy a u-joint tool right now though and save yourself some hassle on the current project and then take it with you on the trail and carry spare u-joints because those are going to be the weak link in your drivetrain (or fuse).
Old 03-31-2007, 08:17 AM
JeepsAndGuns's Avatar
Yep, pretty easy. If you dont have the special socket for the wheel bearing nuts then you will need to buy or rent one. I would just buy one. It should have the 6 slot nuts. To take everything apart just do the following:
Remove brake caliper
remove lockout
remove wheel bearing nuts (two of them)
remove the hub/rotor assembly
remove 6 nuts holding the spindle on
remove spindle, these can be tough, use a plastic dead blow hammer or a block of wood between the spindle and a metal hammer. Do not directly hit the spindle with a metal hammer, it WILL mess it up!
once the spindle is off the shafts will come out.
If I were you, since you have it down that far, I would go ahead and just get new u-joints. Replace the spindle bearings and seals. Clean, inspect and re pack the wheel bearings, and install a new seal on there too.
Old 03-31-2007, 01:36 PM
Tigger4X's Avatar
Thumbs up
Thanks for the tricks, hints, and pointers guys!! It looks like I will be upgrading my tool selection as well.
Any other tips are greatly appreciated!!
