Old 03-26-2007, 07:20 AM
yankeedog yankeedog is offline
two tanks
hello all ,A thirsty boy needs a big canteen .now my 1990 grand wagoneer has the usual stock plastic tank.has anyone stuck a second auxilliary tank where the spare goes?if so which one and where did you stick the spare?i am thinking to try to double fuel capacity without having a big curb scraping tank outback any ideas?
Old 03-26-2007, 07:32 AM
oldmanb777 oldmanb777 is offline
Been done several times that I have seen. One used an early Bronco main tank. I'm not sure what other tanks have been used.
My FSJ doesn't leak...it's just marking it's territory!
Old 03-26-2007, 08:24 AM
shackwrrr's Avatar
i think bjs is developing a tank. otherwise people have used bronk tanks and others have used blazer tanks. its just a matter of what fits.
Jeepless
In to Turbo crap now
Old 03-26-2007, 08:54 AM
DesertWaggy's Avatar
DesertWaggy DesertWaggy is offline
Mine had one that was custom built to fit the area. It also had the dual fill neck so they could both be filled at the same spot. I took both off though. I could look to see who made the tank if you want..
Johnny
1982 Grand Wagoneer (Bone Stock)
Old 03-27-2007, 04:49 PM
goldhammer's Avatar
There was a dealer option tank in the 70's. Was a 25 gal that fit in the spare area, filled from the stock filler, then overfowed into the main to fill that. Made by trailblazer out of Boise. No longer in business, but they show up quite often. They didn'tr hang below the frame rail very much if at all. Usually can be had fo $100 or less + the shipping.
Art
ASE Master Collision Tech
Old 03-27-2007, 07:22 PM
interesting mr goldhammer thank you for your input .wonder how it was plumbed up.one fill with over flow is just simple stupid the way i like it will research this more thankyou.
Old 03-28-2007, 12:35 AM
mdill's Avatar
mdill mdill is offline
Gone. Not Forgotten.
I don't know if the trail blazer tank was "factory approved" or not, but Zack of ZM Jeeps is/was looking in to reproducing or updating one.
Mike D,
Old 03-28-2007, 05:01 AM
actually i am hoping to do this with readily availalble non custom made parts like a bronco tank or a chevy van tank something like that.trying to keep it simple cheap and repairable
Old 03-28-2007, 09:33 AM
goldhammer's Avatar
The two sizes of Bronco tanks will hang down quite a bit. Might look to an S-blazer tank, or have even heard of XJ tanks being used. Do your measurements of what you can live with, prowl the boneyards, and above all else, keep us posted as to what you find and how it works out (with pics, we love pics, we need visual aids!! )
Art
Old 03-28-2007, 12:21 PM
My Wife keeps telling me I need Hearing aids.
Old 03-28-2007, 12:29 PM
GWChris GWChris is offline
I really want extra fuel capacity, but everything I read said that the back tanks hang down too low to be used without lift. If anyone finds one that works at stock suspension height, please post!
Old 03-28-2007, 12:31 PM
MrFurious MrFurious is offline
The F150 rear tanks (18gal) are a lot slimmer than either bronco tank, so if you're looking for a secondary tank that would probably be your best option. The standard Bronco tank (25gal IIRC) will work if you have a 2-3" body lift but will still hang down a little blow the frame rails. The large bronco tank (33gal) is to deep even with a body lift.
Saw someone mention that Suburban tanks from certain years can be made to work as well.
God, Guns, & Jeeps....what else is there?
Jim B.
1979 CJ-5
304 V8 - T150 - Dana 20
D30/D44 Wide-Trac axles w/4.10 gears
Ox Locker in rear & rollin on 35's
Old 03-28-2007, 08:58 PM
bigjeepthing bigjeepthing is offline
There is a company called Aero Tanks that has a tank thats designed to go where the spare goes I think it holds 25 gal. I am having them build a 35 gal tank for back there. I should be getting it in a few days I will let you know how it is.
ITS A FULLSIZE JEEP THING AND NO ONE UNDERSTANDS
Old 03-29-2007, 08:13 AM
twmattox twmattox is offline
Aero Tanks told me they no longer made the tanks for our GWs...
Old 03-29-2007, 08:16 AM
91G-Dub's Avatar
91G-Dub 91G-Dub is offline
I have that tank in my 1991GW. Not plumbed any longer, original owner had it installed at dealer, his son "de" plumbed it before I bought it. Hangs about 2" below frame.
Been thinking about removing it, has one bolt on each side forward end and is welded to back side of trailer hitch.
91G-Dub = Bill Houston
1979/1980 J-10 Junkyard Dog 258 4 speed D44 front AMC 20 rear 3.31 Lincoln Locker Status Running
1991 Grand Wagoneer Gray Ghost (bone stock) STATUS Gone but not forgotten
"The tree of liberty must be refreshed from time to time, with the blood of patriots and tyrants.
It is its natural manure."
Thomas Jefferson
