Old 12-20-2010, 11:37 PM
bigjeepthing bigjeepthing is offline
reverse light
On a 89 wagoneer where is the the reverse light switch on the trans or in the steering column? I put in a th 400 tran and don't see any wire on trans.
ITS A FULLSIZE JEEP THING AND NO ONE UNDERSTANDS
Old 12-20-2010, 11:44 PM
j20brett's Avatar
j20brett j20brett is offline
360 AMC
On a 727 the swith is on the drivers side of the trans just above the pan. TH400 it is in the column.
Build Thread
Fight Crime...Shoot Back.
ΜΟΛΩΝ ΛΑΒΕ
Old 12-21-2010, 10:04 PM
So since I have a 89 column and a 78 th400 I'm screwed
Old 12-21-2010, 10:15 PM
REDONE's Avatar
REDONE REDONE is offline
Let me check some books. I'll post up here in a few minutes...
Where there's a will there's a waiver, I mean a way...
Back: I'm checking to see if the switch assembly for a mid 80s K20 is a direct fit or not...it's taking a little bit...
79 J-10 - The Money Badger!
304/T18/D20/D44s
What's been did:
Holley 4160/Ede' S.P.2.P.
MSD Streetfire based TFI
Custom-hack gauge cluster
Razor swap
2 knob tape deck!
3" homebuilt lift
Half a hillbilly paint job
Old 12-21-2010, 10:47 PM
REDONE's Avatar
Its too dark and dirty out in the shed, but I got a 86 column out back, I'll dig it out and see if it's got provisions for the switch tomorrow.
304/T18/D20/D44s
What's been did:
Razor swap
2 knob tape deck!
3" homebuilt lift
Old 12-22-2010, 06:13 AM
blazer3664's Avatar
blazer3664 blazer3664 is offline
If it dont have provisions for a switch, surely there is something there to make a bracket fit on to it. I know the wiring is simple enough.
modified flares, removable top, OBA w/200psi tank,
LQ4, 4L80e,NWF doubler w/upside down 203
SOA w/ D44s F+R for now
H1 wheels+tires (cut), hydroboost brakes
custom shackle flip
W/F150 springs
-----Coming Soon-----
snorkels,
OX'd D60/14B-FF
Old 12-23-2010, 04:20 PM
REDONE's Avatar
Sorry it took a couple days more than I intended!
The factory GM holes are there but the little piece to hold the switch pin and the switch mounting plate and screw holes are missing:
My best recommendation at this time is to find a matching color steering column from a 3 speed auto chevy truck and install it with your steering wheel, or get an aftermarket floor shifter with the back up light wiring in it. Or go super cheap and easy and just wire it to a dash switch and turn them on when you need them...
304/T18/D20/D44s
What's been did:
Razor swap
2 knob tape deck!
3" homebuilt lift
Dashboard brake light comes on in reverse? Etcetera General FSJ Tech 6 05-13-2010 03:19 PM
Reverse light dilema j20brett General FSJ Tech 2 12-02-2009 01:14 PM
Reverse light switch KaiserMan General FSJ Tech 2 04-05-2007 02:39 PM
Reverse light switch location caionneach General FSJ Tech 5 01-06-2006 10:14 AM
reverse light switch? pb General FSJ Tech 1 10-06-2003 05:37 AM
