Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Wanted
Old 07-25-2021, 12:30 PM
moparman21 moparman21 is offline
column shift parts
I've got a 67 gladiator I want to keep 3 on the tree but the pivot for the shifter is completely worn out. Im looking for the entire collar that the shifter is roll pinned in.
Thanks
1991 G-Wagon.
Old 07-26-2021, 07:03 AM
Thanks
The pivot? Sounds like it's likely just the small spring inside that's causing the problem, same issue I had, where it had broken and required replacement.
--Rob--
My build thread:
My Howell TBI Install How-To:
Old 07-26-2021, 07:14 PM
1991 G-Wagon.
Old 07-28-2021, 09:54 PM
Oh shoot I edited my post a few times trying to get a normal sized photo I forgot the reply. 67 j2000 327 t85 truck. As you can see that "fix" is trash. The pot metal collar is totally chewed up from that cotter pin and clamp slowly eating away at it while in use. Someone added a floor shifter at some point and thankfully left the column linkage but swapped the brackets on the trans ( or I guess technically called levers) so if anyone has a set of the stock ones I'd be interested in those too.
Thanks
1991 G-Wagon.
Old 07-29-2021, 05:21 AM
Heep-J4000's Avatar
My Dad had a 64' wagoneer with the column shift.
It was only a rolling basis so he rebuild it with a Nissan diesel engine and transmission.
Removed the shifter part from the column but the collar stayed on the column.(we could have swapped parts!?)
But he later sold the jeep to a friend!
Don't know if you only need the collar , but the shift lever with parts still laying somewhere on a shelf in the barn.
Let me know if you think you can use the parts and I will have a look at them!
73' Jeep J4000 (named Heep or Desert Dragon) amc 360 V8 converted to LPG with T15/D20 (was my daily work truck for thirteen years and is going to have major overhaul
80' Jeep cj5 350 V8 Chevy/ms420/D300 (a slow ongoing never finished project)
Trucks/car's from the past:
Old 07-29-2021, 08:42 PM
Honestly this is a personal grail truck for me and do not plan on ever selling it so I'd be interested in any parts you have laying around!
Thanks
1991 G-Wagon.
Old 07-31-2021, 05:32 AM
Heep-J4000's Avatar
What I already wrote , can't help you with the shifter collar.
But the other parts are yours for shipping cost and if I can find them!
It's already a couple years the 64' wagoneer was sold , but the leftovers of the column shifter are somewhere.
Old 07-31-2021, 05:37 AM
Heep-J4000's Avatar
Maybe you can send Levelhead a pm ,he is in Canada and has a couple parts jeeps and is very helpful!
Maybe he has or knows the parts you need!?
Old 08-01-2021, 07:39 AM
Appreciate the help, I'll take whatever you scrounge up.
1991 G-Wagon.
Old 08-01-2021, 03:40 PM
Heep-J4000's Avatar
Will have a look for you.
Old 09-21-2021, 03:45 PM
Heep-J4000's Avatar
Haven't found the leftover column shifter parts from my dad's wagoneer.
But in this thread Babywag is talking about a column with three on the three that he is not going to use.
http://www.ifsja.org/forums/vb/showthread.php?t=188292
Maybe that's a possibility if he wants to sell it to you!?
'67 Gladiator-sloppy column shift linkage chrisnsarah General FSJ Tech 0 11-14-2011 10:26 AM
Where can I find Steering Column parts '71 Dr Teeth General FSJ Tech 4 02-07-2008 04:43 PM
transmission shift rod parts source? bigblack'74 General FSJ Tech 3 10-16-2002 05:04 PM
25% off all jeep parts for IFSJA members!!!! billyrb General FSJ Tech 3 09-27-2001 05:03 AM
shift column problems jordanius maximus General FSJ Tech 2 08-25-2001 02:09 AM
