I am perplexed at an ongoing issue. The issue is the signal to the starter solenoid
I have 12.6 volts at battery. And at relay when measuring the large battery cable on the relay. I have replaced the small wire that goes from relay to solenoid. I am getting a single click at the starter solenoid and 10.4 volts at that terminal. If I jump a wire directly from battery to starter there is no issue immediately cranks. If I remove that wire at the relay and directly connect to battery it immediately turns over. Of course this leads me to the relay, but It is a newer relay from Napa. I just put on a new crown that I had and never used. Same thing. What would cause the lower voltage at the starter terminal on the relay. Any help would be appreciated.
