Old 08-27-2010, 08:16 PM
temps425's Avatar
temps425 temps425 is offline
Wiper motor replacement
Hey, whats the easiest way to replace the wiper motor? I started digging into the dash through the gauge cluster, but there is a big panel blocking the wiper assembly. Can it be done from the engine bay?
I dont wanna have to pull the windhsield and drop the dash, anyone done this? Thanks
Old 08-27-2010, 09:43 PM
grandwag89's Avatar
grandwag89 grandwag89 is offline
I can't remember exactly how it's done, the motor itself is under the hood and the shaft goes through the firewall and attaches to the linkage. I had to push it out of the linkage after I removed the gauge cluster, but there wasn't a panel blocking it.
1989 Grand Wagoneer: 360/727/229, D44 F&R, 3.31, 125K
1983 J20: 360/T18A/208, D60FF/D44HD, 4.10, 193K
Non-FSJ:
1980 Ford F100: 302 2V/C4, 9", 2.75, 180K
1992 Ford F150: 302 EFI/M5OD, 8.8, 3.55, 300K
1995 Chevrolet C2500: 350 TBI/4L60E, 14 Bolt, 3.42, 315K
Old 08-28-2010, 07:25 PM
dbuie dbuie is offline
You shouldn't have to go through all of this to access the small nut the motor attaches to. Not sure what year your Waggy is but on my '89 I had to lay on my back on the driver's side floor and place my head about where the gas pedal is. Then I looked straight up and I could see the nut that the wiper motor connects to. I used my snake light to see and used a small socket to remove the nut.
You will think that you're performing yoga to get up there with a small socket but I did it and I'm 6' 220 lbs. Once the nut has been removed gently pry the arm off the wiper motor shaft. Then, you can remove the wiper motor nuts from within the engine compartment. Once these are off, gently remove the motor from the firewall.
1989 GW-Resto Project
My "Labor of Love"
Windshield wiper chatter... at my wit's end iroc86 General FSJ Tech 14 02-15-2012 03:08 PM
Wiper Motor pin outs JpX General FSJ Tech 4 06-26-2009 07:29 PM
wiper motor just runs....wont shut off 70Wangoneer General FSJ Tech 10 05-23-2009 07:53 AM
Need some wiper motor help ('62-'78 style) ColeTrickle General FSJ Tech 2 09-26-2006 09:08 PM
Windshield Wiper fluid system upgrade! Narnian General FSJ Tech 11 12-20-2000 02:06 PM
