AFAIK there's no advantage to a stronger mix over the 50-50 unless your local temps go below -30F or whatever (check the bottle). 100% antifreeze will give you the lowest temperature rating, though it is a less efficient coolant... but you probably don't care if you live somewhere that needs that low a rating.
actually 100 percent does not give you the best deep freeze combination.according to what ive read on the back of the bottle about two thirds ethylene glycol one third water will take you down to about 60 below.
Originally posted by osceola: actually 100 percent does not give you the best deep freeze combination.according to what ive read on the back of the bottle about two thirds ethylene glycol one third water will take you down to about 60 below.
That's what I've seen as well. But I don't wanna go where the temps go that low. My folks taught me to stay away from dangerous places. [img]smile.gif[/img]
Rande--what does that comment mean? That I should be better than 50/50 when the minus 0 weather comes? I'm a desert boy still learning about the mountains and mountain climate. Thanks.
Everyone else who replied: as usual thanks for the info gents.
Brent
79 J10 360-T18-D20 D44's 31X10.5 Edel 1406 w/R4B, speed -despite thousands invested, 360 in putrid death dance-
Originally posted by tgreese: AFAIK there's no advantage to a stronger mix over the 50-50 unless your local temps go below -30F or whatever (check the bottle). 100% antifreeze will give you the lowest temperature rating, though it is a less efficient coolant... but you probably don't care if you live somewhere that needs that low a rating.
I don't know what 100% does at -35+ but at -30
it gets pretty darn thick, I usually shoot for ~60/40
here in Minnesota, the higher the water content the better the heat capacity (as long as there is
some corrosion protection), so in the south I would
go more in the 40/60 range.
Everyone here recommends 50/50. I'm only in my second winter, but it seems to work just fine. We just had a week straight of sub-zero temps, and last year I saw a couple of days of -20. No problems at all with the mix. The nice thing about 50/50 is how simple it is to mix; even the hillbillies here can handle it!
?Honor before honors.?
Sir Richard Burton
Jim<br />-----------------------<br /><br />VinylWag: stock \'87 GW w/factory vinyl top & power moonroof - Engine fire victim!<br />SleepingWag: \'89 GW w/bad motor and stylin\' headliner - 32s and chopped fenders, light bar, dual steering stabilizer, CB, and rhino. - Still in Portland, OR, 450 miles away! Might be coming home sometime this century.<br />\'96 Suburban 2500 LT 7.4L w/roof-mounted gun rack - DD<br />\'84 F250 diesel 4x4 rustbucket, bad tranny (possible parts donor/generator?) - buried in snow
Originally posted by Rande: If you wait until its broke to fix it, its your block you will be fixing.
This is what temp gauges are for! [img]smile.gif[/img] I look at mine--frequently; just made it a habit to cycle the gauges briefly as I drive. I learn what angle the pointers should be at in normal operation so at a glance I can tell if something is heading for trouble. In 30 years of driving I may have come close a few times but I have never boiled a block.
i do belive were not worried about you boiling a block... but when water(antifreeze) freezes it expands, when it runs out of room in an area to expand it will make your block expand and hense break it
79 Jeep Cherokee WT Golden Eagle - Now "Black" Eagle
Mods: Spray Can Bedliner on Rockers, Grill Guard, and Interior floor. Painted Rustolem Black. TFI upgrade.
Future Mods: Carb Rebuild, SOA, Rear Blocks, GM NP208 Swap, GM 1/2 ton Axle Swap with lockouts, Lincoln Lockers front and rear, Some 34" to 35" Swamper Tire.
Originally posted by J10-401: I went jogging today in shorts and a tee-shirt. What exactly is this winter thing y'all are mentioning? [img]smile.gif[/img]
Somebody chuck a snowball at this dude!
CARPE JEEPEM
79 Cherokee "MATA BURRO"
Co-founder and proud sponsor of Ol' Farts 4x4 Club of America
