finally making time
  • rambling_rebel
    • Jul 03, 2004
    • 36
    finally making time
    I'm finally getting time to try and move forward a bit on my step side project
    i'm a little bit stuck on one part of it
    LOTS stuck on many items
    but the current issue is its a 1982 step side
    that i've converted to a 1966 front end
    and after spending a few years trying to find the 3 piece bumper
    i found one and have slowly been preparing it to go on
    last night i went to mock it up and hit a snag
    so i went and looked at my daughter "new to her 77 401 wagoneer" and see the difference
    if you compare the front of the 2 frame rails
    the 82 looks like they extended the frame rail for the one piece bumper
    i'm thinking i'm not the first one that tried this
    (I hope)
    if anyone has done this, did they just "chop" the front and weld a front plate on to bolt the 3 piece to?
    i can post pics if required
    BTW old 82 bumper is for sale, i'll put it in for sale section
    its in really good shape
    thanks for any insight
    i'd like to get these 2 FSJ's on the road this year
    so i'm trying to work on them side by side
  • SOLSAKS
    • Jul 25, 2016
    • 1781
    I don't know much
    but I know you are correct on the frame mounts
    in later years,...they were extended with three holes to accept one piece bumper
    hopefully someone on here will chime in and have more details for you
    but you are on the right track.
    • jpcoutts
      • Jun 28, 2002
      • 2114
      Send me a pic of the front bumper. I'm always looking for a nice one. I can look at my '67 and compare it to the '86 and see if I can tell the difference between the two.
      Jim C
      '67 J3000 Dually
      '86 J20
      '79 CJ5(in pieces)
      '86 CJ7 Doesn't need anything(so why do I have it?)
      Correction- it just needed a water pump!
      • rambling_rebel
        • Jul 03, 2004
        • 36
        Hi all, i had my "welding buddy" here giving me a sober second thought
        it does look like we need to chops off the front of the frame rail
        and i guess drill a hole in the crossmember to bolt to
        i could MacGiver it, but it won't be pretty
        so he's going to step in and do it
        and hopefully not wreck my fresh paint job
        sigh.....
        i'll post a picture of the bumper
        thanks for ringing in
        rr
        • Full Size Jeeper
          • Jul 20, 2014
          • 2475
          BJ'S OFF-ROAD has something that might work.
          Bumper Extension Brackets / Frame Horns
          review0 Review(s) | Questions about this item? Be the first to ask here.
          Your Price: $80.00
          Free Shipping.
          Part Number:05-2644
          Quantity
          1
          ADD TO CART
          REVIEW THIS ITEM
          ADD TO WISH LIST
          Description
          • Full Size Jeeper
            • Jul 20, 2014
            • 2475
            Description
            Bumper Extension Brackets / Frame Horns! These brackets are a weld-on style and allows you to convert early model frame to have the same brackets as the 1979-later models. This allows you to install our later model bumpers on an earlier model rig! 1/4" thick steel plate and steel gussets, and even includes instructions!
            Will not fit Ross Bell Crank Steering Equipped FSJ's (1963-1964, approximately). See Ross Bell Crank Steering style crossmember / frame picture above which shows the style this kit will NOT fit.
            • rang-a-stang
              • Oct 31, 2016
              • 5512
              The chassis changed in 78. When I swapped chassis's under mine (from a 79 Chassis to a 78 Chassis), I cut those frame horns off, the C-channel looking bumper mounts, and welded them to the 78 chassis. The 79 Chassis still had all the same mounting points and threaded holes as the 78 chassis.
              I'm really interested in the bumper too!!! You willing to ship? PM me!!!
              Chuck McTruck 71 J4000
              • Heavy_Metal_Thunder_81
                • Jan 10, 2006
                • 7292
                I have done exactly this on my old '79 Wagoneer. Just need to chop the frame extensions off and drill a couple holes in the cross member to fit the three piece bumper.
                -Jonny B.
                AMC 401 - Pro-Flo 4 EFI
                F D44 - 4.10, Eaton E-Locker
                R M23 - 4.10, Detroit Locker
                1979 Cherokee Chief - Parts
                1979 Wagoneer - Sold
                1981 Cherokee Chief - Cubed
