i have a 87 grand wagoneer with a front soa lift. was wondering has anyone done a shackle reversal and what does it take to do one? any info or pics would be helpful. thanks.
Front shackle reversal
Originally posted by El_Diablosuch as?
Cons: Changing pinion angle (usually) requires a cardon joint and a longer slip yoke, with the softer ride comes a tendency to "nose dive" when braking/descending steep hills.83 J-10 Jeep "Oscar"
360/727/229
I am not familiar with how this one was done but we love the way it flexes. The front drive shaft is a longer than stock and also has longer travel in the yoke.
biggest off road aid is that on a ledge the axle will tuck under instead of trying to push out.... i would imagine that would help more than the negative effects of going down hill1985 Grand Wagoneer-360/727/229/D44/AMC20
2011 Mazdaspeed 3
2012 Focus
2000 Camaro
1995 Mustang
2009 GSXR-600
Originally posted by El_Diablobiggest off road aid is that on a ledge the axle will tuck under instead of trying to push out.... i would imagine that would help more than the negative effects of going down hill
He had a hard time getting the axle positioned far enough forward to keep the tires from stuffing into the aft part of the fenderwells, not to mention he went through three different front driveshaft configurations before he got it right. After attempting to modify the stock one to work, he just called up Tom Woods' and shelled out the money for a 'good' driveshaft setup.83 J-10 Jeep "Oscar"
360/727/229
The front suspension is meant to push into the obstruction, not away from it as stated above.
One of the basic purposes of the Hotchkiss front end that our Jeeps have been patterned after.
Search for some Hotchkiss suspension stuff on the net. Goes back to the 40's or earlier I believe.
J20 projectBP Drivetrain...........
775-537-7918
Originally posted by pitracer1i looking in to doing this because i keep bending main springs and just recently broke a spring. and was curious to know if this could be done.Jeep is gone ~~ Ranger cab truck in the works
393W/C6/203-205, HP60, 14B, 12 bolt H1s, 40" Pitbull Rockers, full hydro, 4 link rear
Build = http://www.pirate4x4.com/forum/showthread.php?t=973973
Yeah, most of what was stated above is spot on, except for the turning radius bit. No clue how that would change.
You will certainly need a drive shaft with a lot more compression, or you risk breaking the t-case when the axle compresses. And if you slam the brakes, the front end will nose dive, which drives me nuts personally.
To help prevent bending front springs, switch to a double military wrap spring. Which will basically double the strength of the main leaf.
When you drive up against a ledge, and load up against it, the shackle in the back rig will tend (from what I have seen, anyway) to let that wheel climb up and forward over the ledge, and then bring the rest of the truck with it.
Maybe we are using different words to say the same thing, but I cannot quite tell.
Anyway, all the other factors aside - the only real downside (as I already stated) to ME, as far as shackle-in-back goes, is the necessity of a longer-slip driveshaft.There is no way to rule innocent men.
The only power government has is the power to crack down on criminals.
Well, when there aren't enough criminals, one makes them.
One declares so many things to be a crime that it becomes impossible for men to live without breaking laws.
