03-03-2009, 02:59 PM
Ring gear bolt tourque
Ok, so i installed my aussie locker this weekend, and went to tourque the ring gear bolts back down and i went to 50 ft/lbs first thinking that was it. Went throught the manual and found a refernce to 108ft/lbs so i started tourquing and broke off a bolt. this is a d44 front by the way. So, someone tell me, what should i tourque to??
" Kaiser" - 1981 J20 113" WB - 360 w/ hei/727/208-d44hd front aussie/d60 rear welded - CS144/Taurus fan/flatbed and roll bar
Future mods - 6.0l chevy, hp60, 14-bolt, NWF Black Box/NP205, 5.13's, SOA, 42's
Build Thread
Fight Crime...Shoot Back.
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
03-03-2009, 05:02 PM
A google search brings a few sites and they all listed 100 FT-LBS.
I dont know for sure, but are you even supposed to re use the ring gear bolts? You might not. But like I said, I'm not sure.
03-03-2009, 06:42 PM
I don't think you are supposed to resure ring gear bolts but I always have anyways. I've always just gone for "really tight" instead of "tight". I don't own a torque wrench.
Jacob Z
1984 Jeep Grand Wagoneer, work in progress
03-03-2009, 07:34 PM
1 blip on setting #5 of my Ingersol 1/2" impact wrench.
03-03-2009, 08:31 PM
your "not" supposed to reuse them but i do anyway! i just torque em to whatever my #4 setting on my impact is(150) i think and use loctite btw!
77Chero,360/t400/231/d300,d60,c14bolt 5.13's 42"rockerz
84wag,360/tf727/208,hp d60,d60,4.10's,37"goodyears(old style mtr)
03-03-2009, 08:59 PM
Ok thanks. Best place to get new ring gear bolts?? It shouldnt have snapped before 100 ft/lbs then. Crazy.
Build Thread
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
03-05-2009, 10:21 AM
i got mine from randys ring and pinion.....excellent product,fast shipping and nice people.....although at almost $5 each(for my 14b), hold on to your shorts
'77 cj-5,
'78 j-10,(not running)
'79 J-10 360ci,t400,D300, SOA-D60w/ARB, 14B w/Detroit,4:56s, 37" TRXUS
'06 Ford F250 super duty crew cab
03-05-2009, 01:10 PM
found them locally at a diff shop for $10 a set
Build Thread
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
03-06-2009, 08:17 AM
be sure and use loctite as well with new bolts.did they give you any insight as to what torque to use?
03-06-2009, 08:44 AM
yeah, that shouldn't have snapped. Yeah, it's a pain but better to find it now then later
You are supposed to use new bolts everytime but I have heard of using the old ones without much issue.
03-06-2009, 09:24 AM
This made me go and look at the install instructions for my Lock-right... it only says "install the ring gear now and torque the bolts". Hmmmmmmm... might need to look into this a little more closely before I install it.
03-06-2009, 04:50 PM
You only have to remove the ring gear if its too thick to get the cross pin out. If the cross pin will slide past the gear, then you dont even have to pull the carrier.
03-06-2009, 07:13 PM
As far as I know though you will have pull the ring gear on all D44s to get the cross shaft out. Does anyone know if you have to on the amc 20 or D60?
Jacob Z
03-06-2009, 09:32 PM
Supposedly, on some 44s you can manage it without taking out the ring gear IF you can get the roll pin out and IF the ring is small enough to get the cross pin out. It's supposed to depend on the gearing. High gears you maybe can; low gears you can't. My 3.54s are right at the cutoff, but I'm expecting to have to take the carrier out.
03-07-2009, 07:19 AM
Jeep Polygamist
I've installed at least a dozen of them after removing the carrier and then reused the ring gear bolts. Never had a problem, yet.
1994 YJ
1986 Comanche
'57 FC-150
Carolina Full Size Jeep Club
www.cfsjc.com
www.patriotguard.org
"Go forth and be a tool".
03-07-2009, 07:21 AM
Jeep Polygamist
I've installed at least a dozen of them after removing the carrier and then used the old ring gear bolts. Never had a problem, yet.
1994 YJ
1986 Comanche
'57 FC-150
www.cfsjc.com
03-07-2009, 06:20 PM
I put mine on without a torque wrench but I am sure it was no where NEAR 100ft/lbs... It did not take anything like that to get them OFF (as it it was pretty damm easy) and I figured since it had gone 200K miles like that with no bolts coming out (hell the thing looked pretty much new...) it was probably ok to tighten them to about what it took to get them off (I am guessing about 40ft/lbs.. if that)
03-07-2009, 09:36 PM
Ok D44 ring gear bolts are 55ftlbs torque, and the carrier bearing caps are 75ftlbs.. since nobody looked it up..
03-09-2009, 08:35 AM
reference for the 55ft/lbs? my manual says 108ft/lbs now that ive found it.
Build Thread
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
03-09-2009, 08:46 AM
Found a good list: Original poster says this comes from spicer
D30
Pinion nut size & thread pitch .750-16
Pinion nut torque (Crush sleeve) 160-500 ft. lbs
Pinion nut torque (solid shims) 160-200 ft. lbs
Pinion bearing preload 15-30 in. lbs.
Ring gear bolt size & thread pitch .375-24
Ring gear bolt torque 70-90 ft. lbs
Carrier bearing cap bolt size & thread pitch .437-14
Carrier bearing cap bolt torque 35-50 ft. lbs
Diff cover bolt size & thread pitch .312-18
Diff cover bolt torque 28-33 ft. lbs
Carrier case ratios 3.55- / 3.73+
D35
Pinion nut size & thread pitch .875-20
Pinion nut torque (Crush sleeve) 170-500 ft. lbs
Pinion bearing preload 15-35 in. lbs.
Carrier bearing cap bolt torque 47-67 ft. lbs
Carrier case ratios 3.31- / 3.54+
D44
Pinion bearing preload 20-45 in. lbs.
Carrier bearing cap bolt size & thread pitch .500-13
Carrier bearing cap bolt torque 70-90 ft. lbs
Carrier case ratios 3.73- / 3.92+
D60
Pinion nut size & thread pitch .875-14
Pinion nut torque (solid shims) 220-280 ft. lbs.
Ring gear bolt size & thread pitch .500-20
Ring gear bolt torque 120-140 ft. lbs
Diff cover bolt size & thread pitch .375-16
Diff cover bolt torque 30-40 ft. lbs
Carrier case ratios 4.10- / 4.56+
D70
Carrier case ratios (D70) 4.10- / 4.56+
Carrier case ratios (D70-3HD) 3.42- / 3.73+
D80
Pinion nut size & thread pitch 1.250-12
Pinion nut torque (solid shims) 440-500 ft. lbs.
Ring gear bolt size & thread pitch .562-18
Ring gear bolt torque .200-240 ft. lbs.
Carrier case ratios 3.73- / 4.10+
Build Thread
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
