Old 02-27-2009, 07:16 AM
cincyjeeprs cincyjeeprs is offline
What do we do now for Cams?
Well, now that Crane Cams is closed, what do we do? Does anyone know who else they made cams for? Summit? Others? Should I go buy up every Crane Cam I can get my hands on, jump off a cliff, or not worry about it?
'85 CJ8 Shiny but Rough
'54 Willys Aero Lark, 161 F-Head six
'90 SJ Everything works - sorta. (edit: most things...edit: some things)
'02 WJ Overland (Red Pill)
'04 WJ Overland (Blue Pill)
Old 02-27-2009, 07:24 AM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
There are still several cam manufacturers out there that will support AMC engines.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 02-27-2009, 07:43 AM
jeepjerry's Avatar
Crane was the only cam company that made AMC roller cams. Other companies ground roller cams, but used Crane blanks, Crane was the only one to make the roller blanks.
1977 J-20, 4bbl 360/t-18, 33"s.
1976 CJ-5 mild 360/t-18, 6" lift, 35"s.
1972 Javelin SST, full roller Indy head AMC 360. Under cunstruction.
AMC ya!!
Alfano Performance
Kenosha, WI 53142
Old 02-27-2009, 08:08 PM
Scoot Scoot is offline
I heard today that Crane plans to re-open after they reorganize. Hope it's true.
Old 02-28-2009, 07:38 AM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
when I talked to their new management guys a month or three back, they mentioned that they were going to reorganize and make some major changes. As I recall, they were all foreign folks, and the non-foreigners I knew there were no longer with them. Not sure what all went down, but sounds not so great. I now only deal with Comp.
BJ's Off-Road
ryan@bjsoffroad.com
Old 02-28-2009, 10:01 AM
crispyboy's Avatar
crispyboy crispyboy is offline
I bought and Engle cam for the engine I'm building right now. Not sure if they do roller cams. They were easy to deal with - answered my novice questions. I went on the recommendations of some other folks and desktop dyno results. At this point all I can do is cross my fingers!
Steve<br />1986 J-20 360 cid/auto, trac-loc, custom efis tbi, flowkooler, aluminum cross flow radiator, rhino-liner, working AC. <br />1990 GW trac-loc, Engle cam and aluminum cross flow radiator.
<br /><br />\"The best Jeeps came from the past when gay meant you were happy and Aids was an appetite suppressant"
Old 02-28-2009, 10:04 AM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
Check with Reed cams, they know AMC from the TransAM days and still build 'em.
