Old 02-12-2009, 08:59 PM
trail mule's Avatar
trail mule trail mule is offline
Rear CV after Shackle flip?
I just did a shackle flip to the rear of my wagoneer . Do I have to hav a cv in my rear driveshaft? I installed an np435, and a np205 with a 1350 yoke in the rear. What have you all done?
Jesus is Coming Soon.
Old 02-13-2009, 09:40 AM
trail mule's Avatar
How many wagoneers are out there with 6 inches of lift, and have a cv in the rear driveshaft?
Old 02-13-2009, 10:22 AM
Jeep Doctor
I did the shackle-flip and lowered the front mount for the rear spring to under the frame, and use J-20 rear springs, and I raised my transfer-case, so it's up about 8"-10" greater difference.
I run 1410-yokes on both ends, and have no difficulty with vibrations, even under heavy load at highway speeds. I do have an anti-wrap bar, though, and my pinion-angle matches my output-shaft angle, so there's no variation in that which would cause things to get screwed up.
Old 02-13-2009, 10:36 AM
Chevelleguy's Avatar
6" springs. Like Bob's, matched angles, no CV.
Old 02-14-2009, 05:37 AM
fullsizejohn's Avatar
fullsizejohn fullsizejohn is offline
When i did my spring over and shackle flip, i had no issues with the stock drive shafts. Just had them both recut.
http://s126.photobucket.com/albums/p...t=100_0302.jpg
'course knowing what i know now, i would have inboarded the springs while i was there(cuz im doing it now). 3.75" bs on the wheels and the 12" tires missed the springs by a hair.
'77 cj-5,
'78 j-10,(not running)
'79 J-10 360ci,t400,D300, SOA-D60w/ARB, 14B w/Detroit,4:56s, 37" TRXUS
'06 Ford F250 super duty crew cab
Old 02-14-2009, 06:18 AM
orangecherokee's Avatar
yeah I was going to say upgrade the yokes and you should be fine. no cv needed.
Old 02-15-2009, 10:15 PM
proto proto is offline
Just wondering: where are you guys finding yokes to upgrade to 1410 u-joints? Do I need to dig out the Spicer catalog, or can I find a good fitting yoke under something at the boneyard?
Old 02-16-2009, 01:13 AM
Jeep Doctor
I just bit the bullet and ordered all new yokes from Jesse at High-Angle Driveline. Don't have the receipt, but it was like $60-$70/yoke at the time, and they were at my door in a couple days.
The 1410 is at the top, with a 13?? below and then one from a D44 below that, and the bottom was the stock front shaft from a Jeep Commando.
I do remember, though, that when I mounted my engine, I sighted through the mock-up block to run the driveline angle right back toward my rear pinion, so the rear angle was minimized.
