Old 03-21-2009, 04:18 PM
Gambler68's Avatar
Rabble Rouser
Bow before your overlord!
Just slappin some of the bed parts on to see how it looks/lines up. I realllllly need a replacement for that one bashed up fender, I don't even want to waste the sanding discs/paint on it, but oh well.
Check out the locking gas cap I bought it for $15 for my volvo, but the moron on ebay had the wrong year listed so it didnt fit the flying brick. Luckily it fit the Glad filler cap perfectly.
My pillars on the bed are rusted bad. Gana cut em out and replace with square tube so I can put some stake side panels on it for dump runs. Bed will be lined with 3/4" plywood with metal L's, bolted through the panels and to the body mounts, and I have a (gasp) 8' JEEP rubber mat to trim to fit for the floor of the bed. I'd sell it, but it weighs a ton, is huge rolled up, and has a small section cut out for a bed mount hitch. So the glad gets it!
Turn the volume down on the video unless you enjoy the best Led Zepplin song ever recorded
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 03-21-2009, 04:29 PM
68_Gladiator's Avatar
68_Gladiator 68_Gladiator is offline
2" on the body lift? and how many inches over stock is that suspension? hows the 327 lookin?
"Go Brow or go home"
67' Gladiator, 383/SM465/NP205, Open Dual Exhaust, Dana 60 Front, 14 bolt rear(disc brakes), 52/56 spring swap, hydro boost, 4" lift, AKA "Dr. Pepper"
Build thread: http://www.ifsja.org/forums/vb/showthread.php?t=122737
Old 03-21-2009, 04:39 PM
Gambler68's Avatar
Rabble Rouser
Yep, 2" lift with about 1/4" more from the rubber pads (barely).
suspension..wellll...i added some thick cj aals to the front, hard to tell until I get matching tires on it (rears are 33s, fronts are 30s I think. Rears I got from a member, amazingly I think they are stock, just not FLAT.
327 is looking might fine, it's basically startable if I had gas to it. Itching for that.
Old 03-21-2009, 04:42 PM
im jealous. ive got 2 327's and a one bare block sittin in the driveway. cant wait to get one put in and fire it up. taking the A/C compressor off one and puttin it on the other to use as OBA. and the new 6 blade flex fan will go on as well. just wish i could get my hands on a 4 barrel intake
Old 03-21-2009, 04:44 PM
Gambler68's Avatar
Rabble Rouser
just watch Ebay, they come around. Seen em go for 75-300 bux.
Old 03-21-2009, 04:46 PM
if you see one shoot me an PM as soon as you can, lol
Old 03-21-2009, 04:49 PM
TexTJ209's Avatar
TexTJ209 TexTJ209 is offline
Lookin' good.
Do you happen to know if the stake pockets on the Willys era beds are the same as the Thriftside beds? As they sell replacement sheet metal for those...
http://www.walcks4wd.com/product.aspx?pid=3261
'05 Chevy Silverado CC Duramax - The DD.
Texas A&M Offroad
Old 03-21-2009, 04:55 PM
janie's Avatar
janie janie is offline
Dexron Impaired
That's a fine looking rig as it sets right now Ryan. Look forward to seeing the progress on this.
Old 03-21-2009, 05:24 PM
Gambler68's Avatar
Rabble Rouser
thats the lurking beast as it sits. it's close..swapped in eaton power steering pump, vac brakes, 4 barrel carb and intake (thanks to Ristow for the carb!), new timing chain and all new seals, NOS Champion HY plugs (dig the little sticker on the heater core, these things are older than me and were still in the wrapper)...thing better run like a raped ape! It's hard to keep a list in my head, but many parts on this truck have come from members..that basically new Motorola alternator I got from Tad about 4 or 6 years ago, front valance and neat lil oil cap from Flint, M715 grill from Baybilly, carb from Ristow, cab and bed from Flatbackdragon's adopted son in law or something, tires from Brutus..couldn't have done it without the board support!
yeah I think those stake pockets are the same. $250 bux for four..ouch. Think some square tube will work better and last a bit longer too with real world use.
Old 03-21-2009, 05:41 PM
Gambler68's Avatar
Rabble Rouser
http://www.walcks4wd.com/product.aspx?pid=1390
here's the rubber body mount pads new 2 bux each not bad really.
Old 03-21-2009, 06:08 PM
Looks good...but your rear shackle angle is seriously out of wack. Flipped it should be pointed down and toward the back a bit.
1971 Gladiator J2000 Custom-Cab Platform-Stake Dump
1970 Gladiator J3000 3407Z Camper Truck
1963 Gladiator J300 Thriftside
Visit the Land of Off Topic!
http://gwamp.com/offtopic/index.php
Old 03-21-2009, 06:10 PM
Gambler68's Avatar
Rabble Rouser
I know I couldnt really get em to budge much. Think I have to take em off and try grease em better and see if it'll go on better...postmount springs are sorta hard to install (least I though so)
I think iirc thats the only way the springs fit, although they measured really close to the stock ones. I dunno..
Old 03-21-2009, 06:15 PM
It is good to knock the dust bunnys and spiders off the Jeep projects when Spring comes around!
Old 03-21-2009, 08:03 PM
TexTJ209's Avatar
Yeah...either way I'm gonna take notes on how you handle yours, as my rear two are a bit chewed up.
Texas A&M Offroad
Old 03-21-2009, 08:10 PM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
The stake pockets are the same as the Willys. Nice progress you're making.
Old 03-21-2009, 08:19 PM
willam's Avatar
willam willam is offline
Just grab a mud flap off an old trailer....they are nice and thick. Best of all is the price, I found mine on the side of Route 287.
Old 03-22-2009, 10:47 AM
Gambler68's Avatar
Rabble Rouser
Yeah I cut a few out of an old MT tire.
I just took a 6' prybar and flipped the shackles up, sits a bit lower but at least it's correct now Maybe my shocks will fit now..
Old 03-22-2009, 02:42 PM
I do wish I could find one of those beds. It's going to be a nice truck when you get it there...
Old 03-24-2009, 09:17 AM
NVJEEPER's Avatar
NVJEEPER NVJEEPER is offline
Looks GREAT!!! Them Willys fenders way off the tire is ....cool!!!
Damon
'85 Grand Wagoneer
Old 03-24-2009, 09:59 AM
J.J.'s Avatar
J.J. J.J. is offline
Lookin' good.
Joseph
77 Cherokee 4 door
