Old 01-31-2009, 09:08 PM
j20brett's Avatar
j20brett j20brett is offline
360 AMC
Shortened the Wheel Base today...
Its Short!
Ended up moving the hangers 18 inches forward. A total of 24 inches of frame removed behind the hangers. That bed was way heavy. Flatbed and new driveshafts next. Took 2 of us 12 hours to get it done!
Build Thread
Fight Crime...Shoot Back.
ΜΟΛΩΝ ΛΑΒΕ
Old 01-31-2009, 09:20 PM
Dmntxn77's Avatar
Dmntxn77 Dmntxn77 is offline
Hey watch this...
Looks good...
Why didnt you go ahead and mount those springs under the frame while you were at it?
Old 01-31-2009, 09:25 PM
j20brett's Avatar
360 AMC
Would have been too much lift for now. Need to be SOA in the front to inboard the springs. Dont have the $$ for highsteer yet
Build Thread
ΜΟΛΩΝ ΛΑΒΕ
Old 01-31-2009, 09:29 PM
Dmntxn77's Avatar
Hey watch this...
How much lift you running in the front?
If those are 4" springs, I am sure that you could inboard the springs, ditch the blocks, and add a longer shackle to the front to make up some of the difference. That would only leave you an inch or so higher in the rear which I wouldnt think would be a big deal. The advantages of an under frame mounted, shackle flipped rear would make it worth it...
Old 01-31-2009, 09:34 PM
j20brett's Avatar
360 AMC
Its only 2 inch springs in the front. Rancho 44044's. And i do plan on getting rid of the blocks back there now. Had to have them with these worn out waggy springs. Should set it close to just right w/o the blocks in.
Build Thread
ΜΟΛΩΝ ΛΑΒΕ
Old 01-31-2009, 09:46 PM
Dmntxn77's Avatar
Hey watch this...
Ahhh, I see...
The rear would possibly end up quite a bit higher with only 2" springs up front.
Still though, I bet that if you added a longer shackle to the front, and designed the rear spring mounts to be as close to the frame as possible and make the new rear perches to sit as close to the tube as possible, you could make it work out well...
BTW, Im not trying to cut down your work, because it looks like you are doing a great job... Im just throwing out ideas...
Also, I dont know how well they would work with 2" springs, but I have a set of 4 AAL's that I will be selling soon if you need a touch more spring lift...
Old 01-31-2009, 10:17 PM
glady8r's Avatar
glady8r glady8r is offline
Banned
nice whats the wheelbase now I was thinking of doing this to my gladiator
j20brett's Avatar
360 AMC
I appreciate the advince. But its set for now. Been working on it for 12 hours today. I think itll settle in fine once i add the flat bed and back half cage eventually. Heck i need to take a few leaves out of the front springs to get them to flex a bit more. Thanks for the offer
Build Thread
ΜΟΛΩΝ ΛΑΒΕ
Old 01-31-2009, 10:18 PM
j20brett's Avatar
360 AMC
131-18=113"
Build Thread
ΜΟΛΩΝ ΛΑΒΕ
Old 01-31-2009, 10:23 PM
Dmntxn77's Avatar
Hey watch this...
Old 02-01-2009, 07:53 AM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
Nice work Brett!
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 02-01-2009, 08:57 AM
Nice transformation! Giterdun!
Old 02-01-2009, 10:51 AM
Gambler68's Avatar
Rabble Rouser
I think it looks badass and I hear ya, do what ya can when ya can. Least you're gitternherdun
ps you suck for having a HOIST and that SHOP to work in. Suck.
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 02-02-2009, 02:00 AM
j20brett's Avatar
360 AMC
Haha thanks for the comments. Just got home from school where ive been working on this. Got the rear crossmember/bumper dont and the gas tank relocated behind the axle. Built the tank skid/support out of 1/4" plate and weighs about 80#s! But should support the weight of the truck if it lands on a rock. Only hangs 2 in below the frame rails. Forgot my camera so pics at soe point this week.
Build Thread
ΜΟΛΩΝ ΛΑΒΕ
Old 02-02-2009, 04:59 AM
4x4fEvEr's Avatar
4x4fEvEr 4x4fEvEr is offline
I seriously wouldn't do that. Three rides on my ranchos and they were bent and broken in half. If you search the 4404s'4 there's a lot of em breaking. Be sure to put something on the frame behind the shackle so they won't fould up the shackle
Old 02-02-2009, 09:26 AM
j20brett's Avatar
360 AMC
Bent mine twice now and i do have a shackle stop.
Build Thread
ΜΟΛΩΝ ΛΑΒΕ
Old 02-02-2009, 09:44 PM
j20brett's Avatar
360 AMC
Well here she blows, nearly finished up.
Build Thread
ΜΟΛΩΝ ΛΑΒΕ
Old 02-03-2009, 07:48 AM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
A truck that will turn like a Chero, you're gonna love that. I'd miss the weight over the rear wheels though... always thought that gave the Chero the perfect balance.
Old 02-03-2009, 07:54 AM
Lindel's Avatar
Now you need to put a mini-flatbed on it.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 02-03-2009, 09:21 AM
NVJEEPER's Avatar
NVJEEPER NVJEEPER is offline
and use chrome on it to match that trim ring on the back of your cab. Looks great! That pic of the front while on the hoist is way cool
Damon
'85 Grand Wagoneer
