Old 01-02-2009, 08:46 AM
dlowrance's Avatar
dlowrance dlowrance is offline
Anybody running adjustable air shocks?
I used to run these on my Z71 and liked the solution - run them low when no-load in the bed for ride, and increase the pressure when towing/hauling...I can't see why they wouldn't be just as beneficial on the J10...
Anyone running them now? Thoughts?
Dale
80 W/T Cherokee - "Liz"....4bt??
69 J3000 DRA Dump - King Triton!!
Old 01-02-2009, 09:39 AM
That is how I did a poor man lift on my first Waggy back in the 80s. I gained about 2.5" lift when I wanted it. I had 120 psi rated shocks on the front and 150 psi rated on the back and ran them 30-40 psi in town and 100 in the front and 130 in the back to get lift for the beach. They worked great for what I used the Jeep for.
Old 01-02-2009, 10:12 AM
dlowrance's Avatar
yeah that was in the back of my mind too...I'm throwing a set of BJ's shackles on the front and probably an AAL too (springs are pretty sprung on the front) and figured that if both were there I might be just a bit lopsided. I could block the rear and I might still, but I'm going to need the occasional towing gain that you can get from the air shocks....and if it lifts her an inch or so, hey even better!
Dale
Old 01-02-2009, 10:47 AM
waynestiles's Avatar
waynestiles waynestiles is offline
running them on the back of my 87 GW to cure wagsag and for pulling my camper. hope to re-spring next summer but until then they work nice--so far
"Sacred cows make better burger"
Old 01-02-2009, 10:58 AM
Geeeep's Avatar
Geeeep Geeeep is offline
I've got a set of Monroe's in the back of my '87
Flint, what shocks did you use up front?
Dave Pitts, located directly over the center of the earth!
GW - 87 GW 360/4bbl/727/208 Vinyl floor, manual windows, no woodgrain
Find someone to haul your Jeep here: YT Hauling Schedule
Old 01-02-2009, 11:11 AM
I used Gabriel for the front with exposed air bag because the type with the metal tube over the air bag would not clear the shock tower.
Old 01-02-2009, 01:36 PM
Mikel's Avatar
Mikel Mikel is offline
How do the shock mounts take the extra load?
1969 M715, 6x6 project
1963 J300, 4BT, NV4500, NP200 D60/D70.
Old 01-02-2009, 01:41 PM
When I went fishing on Padre Island, I would load 1 to 3 dogs, enough camp gear for a couple days for 1 or 2 people, lots of fishing gear, 15' kayak on top, extra gas, parts, fluids, etc then air up. They took the load and beach terrain just fine.
Old 01-02-2009, 02:49 PM
dlowrance's Avatar
I wouldn't expect any trouble, as long as everything's in good shape/no cancer/etc...
Dale
Old 01-02-2009, 03:22 PM
CustomWag's Avatar
CustomWag CustomWag is offline
My 84 had them in the rear when I bought it 11 1/2 years ago. Replaced them with Gabriels (I think, could be Monroe) about 5-6 years ago. Just the last 6 months I've been losing air a little, guy at the tire store said the shocks usually don't go bad, the air lines get cracked, etc. I need to get a set and install them and see if it fixes the problem.
I really like the flexibility. Usually run around 70 lbs (got sag in the rear and it keeps it level), but when I have to haul something heavy (firewood, shrubs, etc) I air them up to about 120 lbs. The sticker says the limit is 250 lbs! Never tried that, only a couple compressors in town can get them up to 120.
Rick
84 Custom GW
360/727/208/d44f/AMC20r/3:31
Manual windows/locks/seats
Old 01-02-2009, 08:40 PM
nitrogen??
I just had my new tires filled with nitrogen---less prone to leakage--supposedly. I was airing up all the time with the old ones and the gas stations started charging for air-ups as a profit center I figured it cant hurt anything and it was only 5$/tire and might actually save some $ in the long run over the "fuel saving".
now I'm wondering about having them let the air out of the air shocks and filling the shock systems with NI too to help avoid any leakage. think it'd work???
Old 01-05-2009, 10:18 AM
ironroad29's Avatar
ironroad29 ironroad29 is offline
Please god don't use air shocks, the shock mounts are not designed to hold the weight of the vehicle, if you need some assist in the rear use a air bag seup that goes between the top of the axle and the frame, air shock are nothing but trouble. and the nitrogen thing is a scam. the air around you is already 78% nitrogen , so a little more isn't gonna make that much differance.
Looking for a j truck in VA.
1977 impala coupe lt1 swap in progress
2004 crown vic LX sport
1997 2 door Tahoe sport
preparing for a bleak future...
Old 01-05-2009, 01:01 PM
dlowrance's Avatar
I actually considered this...where would you find a set for our rigs? All the websites I use don't list our rigs as an option...or would you just custom fit one?
Dale
Old 01-05-2009, 03:18 PM
CustomWag's Avatar
Not disputing your claims, but only going on my experience, my rig is 25 years old, and has ~ 268,000 miles. Has had air shocks for at least 11 1/2 years and at least 177,000 miles. Not had a problem yet with the shock mounts, though saying that, I would expect that to be the next thing I deal with.
Could have something to do with salt on the roads I suppose, mine's been in Oregon all it's life.
Rick
84 Custom GW
Old 01-05-2009, 07:37 PM
mrtazwrench's Avatar
mrtazwrench mrtazwrench is offline
PO put some on My 87 J20, not sure if the were for that application or not, looks like some of the brackets may have been fabed. If I don't get you any pics maybe you can get a look at them when you're up for the next appt. at Mayo.
Chad
Quote from Bubbles, on Trailer Park Boys...
"Let's see that red blue green **** sucker build one of these without duct taping it together!"
88 wag
87 J20
82 J20
Parts vehicles: 4 Wags, 4 J20's, 2 J10's, 2 J4K's
