Old 12-18-2008, 08:14 PM
El Jefe's Avatar
El Jefe El Jefe is offline
Its the little things
that make ya wanna pull your hair out.
I went over to the parents to get my driveshaft in. Should take like 5 minutes right? well it was going all good. Got it bolted to the transfer case. went to the rear end. got 3 bolts in. Tightening up the last one and it gets hard to turn. so I back it out and clean out the hole with a wire brush since I dont have a tap that thread. Put the bolt back in. It goes a little further and BREAKS
so now I gotta pull the stupid yoke off again and try to drill that sucker out. This is taking so long I wondering if I should put the 44 back in. seesh. Im just venting. I'll get it. just frustrating.
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
4" lift, 35 inch retreads
Old 12-18-2008, 08:23 PM
cu4whln's Avatar
cu4whln cu4whln is offline
Sympathy your way.
Drilling bolts out is a major PITA.
I have skied in Ogden years ago.. nice little town.
1979 Chero: "Madness"
2001 XJ : Driver
TJ Rubicon
2010 JK - Islander "Wifes new ride"
"Madness" build here:
Old 12-18-2008, 08:25 PM
Eugene 1's Avatar
Eugene 1 Eugene 1 is offline
Location: La Crosse,Wisconsin formely of Wichita,Kansas
ive had many a days like that !
1979 Cherokee Dodge CTD with running Gear Build thread:
MoPaR
Old 12-18-2008, 08:31 PM
El Jefe's Avatar
Originally Posted by cu4whln
Sympathy your way.
Funny. I lived here my whole life and never been sking. I love Ogden, except now cause its freezin.
Im just gonna pull the yoke off tomorrow and see. I dont dare drill it under the chero. I know I couldnt get it straight.
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
Old 12-19-2008, 08:43 AM
GW Fisherman's Avatar
GW Fisherman GW Fisherman is online now
Man you are a funny dude. That just cracked me up.
But the little things can sometimes or real easy.
2001 Subaru Outback 3.0 - Mamas assault vehicle
1989 Grand Wagoneer - DD and Boat Hauler
1985 Mercury 115hp inline 6 outboard
1989 Champion 184DCB - Bass boat
Old 12-19-2008, 08:46 AM
dlowrance's Avatar
dlowrance dlowrance is offline
Is any of the bolt sticking out? Do you have a torch? If yes to both you might be able to get it out without drilling...vice grips on the bolt, heat the housing up, not a lot, and try to work it out...heating the cast housing will cause it to expand...don't overdo it...cast doesn't like too much heat, you'll basically anneal it.
Dale
80 W/T Cherokee - "Liz"....4bt??
69 J3000 DRA Dump - King Triton!!
Old 12-19-2008, 09:19 AM
Headhoncho's Avatar
I've lived a half hour from Phila my whole life and have never seen the Liberty Bell.
You're right, best to do it on a bench. Is the yoke off the 14 bolt? There are write-ups (pirate 4x4 I would guess) about people drilling out the thread holes to replace the straps with u-bolts. I'll do it to mine eventually.
JR
1966 mustang fastback
'07 Dodge Charger 3.5
Old 12-19-2008, 10:31 AM
El Jefe's Avatar
nothing sticking out unfortunaly. Im heading out in the snowy freezing cold right now to pull the yoke off. then go in the slightly less freezing garage and start drilling. I may hafta drill it out for u-bolts. Im gonna try to get just the bolt out. but we'll see.
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
Old 12-19-2008, 11:36 AM
dlowrance's Avatar
Drill it the tap drill size...to calculate that for 75% thread depth the formula is
D-(1/N) = T
N=Number of Threads per inch
D=OD of bolt (.3125 for 5/16)
T=Tap Drill size
or you can use this chart...
http://www.korit.com/tapndrill.htm
make sure you get a good center punch mark to start with...grind the bolt off flat before you start if you can so the drill bit will follow the center punch mark and not the variations in the break...
Dale
Old 12-19-2008, 06:30 PM
El Jefe's Avatar
fixed my problem
got it from Tom Woods. 45 bucks.
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
Old 12-20-2008, 08:46 AM
dlowrance's Avatar
That's a darn sight easier than drilling!!
Dale
Old 12-20-2008, 09:15 AM
FSJ Guy FSJ Guy is offline
Often times, once you get a bite in it, the remaining bolt piece will turn itself out. Let's hope!
Ethan Brady
www.bigscaryjeep.com
Old 12-20-2008, 09:42 AM
fixed my problem
A+ for the proper solution!
Old 12-20-2008, 12:08 PM
Randyzzz's Avatar
Randyzzz Randyzzz is offline
I lived in Ogden from 90-96. Managed the Pep Boys in Riverdale. Lived up in Eden for 2 of those years. Was back to visit 2 years ago- the place sure has changed alot since then.
Randy S.
It's not what you buy, it's what you Build.
88 Grand Wagoneer
82 Scrambler
73 VW Bus
www.oldsoulsretros.com
Old 12-20-2008, 02:52 PM
El Jefe's Avatar
I went to Six States and they wanted 176 bucks for a standard replacement yoke. I can get a whole nother 14 bolt for that. So my pops called up his buddy at Tom Woods. Had one in stock. 75 bucks, but he knocked off30. so WOO HOO! I'm so glad I got this one with the u-bolts.
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
Old 12-20-2008, 02:54 PM
El Jefe's Avatar
Its even changed alot from 2 years ago. we got so much more going in downtown. I love it here really. And its so nice to see the change from the 80's and 90's.
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
Old 12-20-2008, 02:55 PM
El Jefe's Avatar
I tried drilling the other one. got the hole pretty straight. put the easy out in, heated it up a bit and snap. two piece easy out.
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
Old 12-20-2008, 03:29 PM
Headhoncho's Avatar
Easy outs S*CK!!!!!! They are a waste of money.
JR
Old 12-20-2008, 04:06 PM
1977cherokeechief's Avatar
1977cherokeechief 1977cherokeechief is offline
they are a waste of money, if you cannot afford the MOST expensive set, which is a waste of money.
nate
the new fixer upper
1977 cherokee chief
360, th400, QT
33" tires
edelbrock 600cfm
82 mustang 5.0 5 speed. ford racing intake, edelbrock, offbrand long tubes, and glass packs.
Originally Posted by jamsni
Just explain that you are trying to do your part to stimulate the economy. Buying it is just the right thing to do.
