Old 12-11-2008, 07:09 PM
brielly's Avatar
brielly brielly is offline
Loose steering
I was just told by my mechanic that my steering was loose (sure feels like it) Anyway he said tie rods and pitman arm was loose. I understand the tie rods being loose but what should i check in regards to the pitman arm? Its a drop pitman arm from bj's that i got with my lift a few yars ago. The truck almost feels like it has bump steer on occasion which I thought wasn't supposed to happen with the drop pitman.
For Sale Custom built reproduction Rhino Grilles PM me for details or email rrielly2@comcast.net
1982 Cherokee Chief 258 6 cyl, T-5, NP208, mopar mpfi, hydroboost brakes.
1983 Jeep Cherokee Laredo 258 6cyl, 4.0 Head, MPFI, t176 4 spd, np 208, Hydroboost Brakes msd 6a & blaster 2f coil, BFG 31/10.50/15 tires, BJ's 4" Lift *SOLD*
Old 12-11-2008, 07:33 PM
KJ Ryu's Avatar
KJ Ryu KJ Ryu is offline
There's a hex screw on top of the steering box to adjust the pitman arm. Only turn about 1/4 of a turn at a time, test drive, adjust as necessary.
Ron
2005 KJ, Hit-n-Run, 2am 6-17-2012, Totaled.
1977 SJ J10, 2v304, T18, D20, 37x14s, SOA & SF on tons, still ugly waiting on clutch
1978 SJ Wagoneer, 360, QT, 33x12.5s, lift by Sawzall NOT Running
1993 D150 "1-legged dog"DD
Originally Posted by Mars
One man's trans leak is another's penetrating oil
Old 12-11-2008, 08:56 PM
jmundale jmundale is offline
a drop pittan arm in itself wont necessarily aleviate bump steer depending on how your angles are - do you have a photo of your linkage angles? im sure the experts could determine what if anything you might need to look at/replace.
