80 j10,,got the stock analog clock to work as someone removed the connector, new door rubber, glove box, and found out to my amazement the cigarette lighter works, also truck only broke down once today
(loose cable at the seloniod)
Noticed a factory sticker on the door jamb that states the vehicle should not be driven over 70 mph (whats up with that)
Wag has been running bad since all the vac leaks were repaired, simple carb adjustment, runs perfect smooth and no more stalling at stops. Shifts alot better as well.
Got to thinking that jeep must of had the intentions of giving people something to do on weekends other than driving these vehicles, man that sure worked, Sure gets yur mind off your day job
Lou
