Old 10-05-2008, 11:43 AM
81j10honcho's Avatar
81j10honcho 81j10honcho is offline
bolt on exhaust setups for fsjs
hey people i was woundering im currently doing a couple of projects and iveknown for a while that there are no bolt on exhaust kits for fsjs would a bolt on exhaust market like this apeal to any of u if i deside to start making them
for fsjs
81 j10 honcho with a stroked amc 360/727/208 tts soa kit, and bjs 4inch lift 35inch baja claws
http://www.fullsizejeep.net
might be getting outa the fsj game geuss im not im getting further into it with possibly another j10
wanted hemi6
Old 10-05-2008, 08:34 PM
FloridaFSJ FloridaFSJ is offline
It's called flexpipe and band clamps.
Old 10-05-2008, 09:07 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
I think there are a lot of people that would probably be interested. The real problem you're going to run into is that no two FSJs seem to ever come out the same. You could certainly make a prefabbed setup, though, and people could work around that.
aa
Anthony
1983 J-10 - 4.6L(MPFI)/CS144/NV3550/D300/44/44/3.54/32
1983 Honda CB1100F
1983 Honda CB1000C
Old 10-05-2008, 09:16 PM
FSJ Guy FSJ Guy is offline
A long time ago, I made a cat back system with the pipe pieces you buy at the parts store. Use the 45 and 90 degree bends to get over the rear axle. It actually worked pretty well.
You could clamp it all together, but I welded it together with a stick welder, which worked fine since it didn't have to be pretty.
Ethan Brady
www.bigscaryjeep.com
Old 10-05-2008, 09:36 PM
TPICherokee's Avatar
We are in the process of having a cat-back back and cat-forward system for 80-91 Wagons. Here are the specs:
3" mandrel bent aluminized pipe
Stainless steel muffler
Hi-flow catalytic convertor will be optional for those of you who need or want one.
