Old 09-30-2008, 05:01 AM
Adam17's Avatar
Adam17 Adam17 is offline
Rear Cargo Area??
Who has replaced the rear cargo area panels of their GWs. What have you used to replace those cardboard wonders that jeep put in there. Has any thought of any thing such as putting a hing on it for further access to the quarter panel?I found an army of ants living inside of mine this past weekend.**PICS would be great!**
1986 Jeep Grand Wag
133K Miles 360/TF727/NP228 A
militaryjeepers.com
coastalcarolinaoffroad.com
Old 09-30-2008, 05:32 AM
men in black's Avatar
I've made a set out of 1/8" ABS for my GW.
using a template
cu4whln had a idea of making the passenger side one piece and using
a piano hinge on a fold down door
I'm using those X-mas tree retainers to hold them in place.
then replacing the carpet.
http://www.auveco.com/product/xmas.html
"edit" here's a photo of the one I made for cu4whln out of ABS
he didn't want speaker holes
1990 Grand Wagoneer.. black with sand interior.. 70,000 miles,
Razor grille, Hella H4 headlights, Piaa driving, LED taillights, tinted windows.
custom full length center console with cup holders.
On the road again
Old 09-30-2008, 09:53 AM
Slinger646's Avatar
Slinger646 Slinger646 is offline
Im anxious to see this too, as I have no side panels in my Chero. I was thinking od using some steel and then mounting my axe ans other crap to it.
Old 09-30-2008, 10:31 AM
Zorm's Avatar
Zorm Zorm is offline
I'll shoot you pics of mine. I actually cut some sheet metal the same shape as the cardboard then put the inside cover stuff back on the metal and made some "slip over the bottom lip" things to keep the bottom in place. Got some drawer latch thingys from Granger and modified them to use. I am thinking of redoing them with lighter metal or maybe something else.
Anyway, I can turn the drawer things a 1/4 turn and remove the side pannel for access for storage on both sides. Like I said I will get you pictures as soon as I can.
83 Cherokee 4dr WT(axles)
4" Rusty's lift, 32x11.50s,
4.6 stroker modified MPFI engine (building/install phase)
Flowmaster exhaust
66 Mustang coupe
2007 SeaRay 205
71 F-250 Camper Special
Join date actually Apr 1997
He guides my path, forgives me when I stray and lights my life.
Old 09-30-2008, 11:14 AM
ChileWaggy's Avatar
ChileWaggy ChileWaggy is offline
I´m in the process of replacing the panels at this moment.
I already have one finished.
I made them from 9mm MDF board.
1989 Grand Wagoneer
Vortec 6.0L, Nelson Performance Tune, Air Aid Kit.
4L60E/NP 241.
BJ's 4" lift.
31x10,50 BF Goodrich.
Drivetrain Swap Here:
http://www.ifsja.org/forums/vb/showthread.php?t=84851
Old 09-30-2008, 10:38 PM
Langdon Langdon is offline
I used 1/8" diamond plate aluminum...wire brushed it cause it was too shiny.
Langdon
'80 Model 17 "Cherokee S" 305 Vortec FI/4L60E/241C/44,20/3.73/33
Old 10-01-2008, 07:07 PM
JPSwapMohn's Avatar
JPSwapMohn JPSwapMohn is offline
I had some pics I pulled offline (car domain, maybe?) of some panels someone made from hardwood plywood (1/4" maybe?). Stained and added marine-grade speakers. He used a piece of molding along the top to hold in place and added those pop-up T-bars as tie-down points.
I thought it looked pretty dang sharp. The carpet on the wheel wells looked out of place, but the panels were nice.
One day I will wake up and realize that my jeep is complete...one day, I just know it.
88Wag, LT1/4L60E/NP229, Dual 2.5", F150 fuel cell, Rear discs, Aussie rear, LDS front, 4.10 gears
97 Orvis ZJ - DD
95 YJ - D44's, SOA on OME leafs, ARB's, 4.56s, Blisteins, 35" KM2's
http://s552.photobucket.com/albums/j...wapmohn/Jeeps/
Old 10-01-2008, 09:08 PM
cu4whln's Avatar
cu4whln cu4whln is offline
using a template
Hmm - maybe I should come pick those up soon .. huh ?? LOL
[ did you add the ABS kick panels in my stuff yet ?]
"Someday", as the Jeep goes back together, I'll share some pics !
1979 Chero: "Madness"
2001 XJ : Driver
TJ Rubicon
2010 JK - Islander "Wifes new ride"
"Madness" build here:
